101 Fork uses
/ 101 Fork uses #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
A set of forks is so handy.
The guy at the store claims this spool weights 80lbs.
Probably a little less than that. Set it up in the forks and the spool spins with very little effort.
Well worth the money for a multitude of reasons.
Fred
/ 101 Fork uses #2
Phred, my guess is that the cinder blocks weigh more than the spool, but they sure make good spacers. That's really using your head. You could string fence-wire/barbed wire the same way...maybe even get two or three spools going at the same time if your forks are adjustable./w3tcompact/icons/cool.gif
/ 101 Fork uses
Jim,
Good idea on the fence wire, I had not though of that.
Maybe you could load up a few spools, attach the ends to a post and drive backward to string the wire.
Fred
/ 101 Fork uses #4
On a related subject I saw an attachment on Ebay that you put on a post hole digger instead of an auger and then you can use the phd to spool wire back up.
