101 Fork uses
   / 101 Fork uses #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
A set of forks is so handy.
The guy at the store claims this spool weights 80lbs.
Probably a little less than that. Set it up in the forks and the spool spins with very little effort.
Well worth the money for a multitude of reasons.
Fred
   / 101 Fork uses #2
Phred, my guess is that the cinder blocks weigh more than the spool, but they sure make good spacers. That's really using your head. You could string fence-wire/barbed wire the same way...maybe even get two or three spools going at the same time if your forks are adjustable./w3tcompact/icons/cool.gif
   / 101 Fork uses
Jim,
Good idea on the fence wire, I had not though of that.
Maybe you could load up a few spools, attach the ends to a post and drive backward to string the wire.
Fred
   / 101 Fork uses #4
On a related subject I saw an attachment on Ebay that you put on a post hole digger instead of an auger and then you can use the phd to spool wire back up.
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2025 K4230G UNUSED Metal Storage Shed (A53117)
2025 K4230G UNUSED...
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
CAT Skid Steer (A50322)
CAT Skid Steer...
