10' x 10ga shear
/ 10' x 10ga shear #1
OutbackL130
chickamauga
L130, 420
I need a hydraulic or mechanical shear with a capacity of 10' x 10ga.
I've narrowed my search down to either of these two pexto shears. I cant tell if they are the exact same or which is newer.
This one is 6 hours from me and I can travel there to see it in operation. he will take $7000 for it and then I will have to pay for it to be shipped to my shop.
Pexto 10' 10ga Shear | eBay
This one is much farther from me and I will not be able to see it in person before the purchase. They say it runs fine and I would have to take their word for it. I can probably get this shear for $5500.
http://www.ebay.com/itm/27133763336...l?_sacat=0&_from=R40&_nkw=271337633367&_rdc=1
I was burnt on a stomp shear before when the seller told me it worked and I found out after the purchase it in fact did not. Any advice on a purchase this large? This will be the most I've ever spent on a single used machinery. What things should I look for in a shear? I have only single phase electric but all shears of this size are 3 phase and I will have to run a phase converter.
/ 10' x 10ga shear #2
See when the last time the blade was sharpened. I wouldn't buy one without either getting to see it work or getting some kind of warranty from a reputable used machinery dealer.
/ 10' x 10ga shear
I was concerned about the blades needing to be sharpened. I asked how much and they said it would be about $200. Does that sound right?
/ 10' x 10ga shear #4
Last I looked, there were 3 watchers on that shear, so $5500 may not be a done deal.
I've had luck getting a local sheet metal guy (who has a bigger shear) do some jobs for me in this gauge for only a small fee. Anyone near you that could help out?
Also, I've had reason to call Pexto a few times and talked to their staff. They can tell you who can do it, where it can be done and how much to expect it to cost for a sharpening.
/ 10' x 10ga shear
I have a local shop shearing my metal for $15 a 4x10 sheet. Sometimes there are only 4 cuts out of a sheet. The convenience of being able to do the work in house right when I need it is the main reason I want a shear.
/ 10' x 10ga shear #6
I don't know what it costs to sharpen a blade but $200 sounds pretty reasonable. It might be a good idea to see if you could pay a machinery dealer to check it out for you? I think having a shear would be great tool to have as well as a brake and a roller but that costs a lot of money.
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
1997 John Deere 5300 (A60462)
1997 John Deere...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
Byron 1514 (A60462)
Byron 1514 (A60462)
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
