10" drill press; What's 10 inches about it??
   / 10" drill press; What's 10 inches about it?? #1
beppington
Elite Member
of my
Here
I bought a Ryobi 10" drill press 7 or 8 years ago, not really focusing on the 10" part, just wanted a decent drill press, & it did the trick for what I needed at the time.
A friend of mine needed to drill some 4x4s, so also bought himself a 10" drill press, & was disappointed to find out a 10" drill press apparently doesn't drill a 10" deep hole. I think it drills a 2.5" to 3" deep hole.
So ... What's "10 inches" about a 10" drill press?
   / 10" drill press; What's 10 inches about it?? #2
Hi beppington. Measure your drill press from column to the center of the drill chuck. It should measure 5" meanimg it has a 10" swing. :thumbsup:
   / 10" drill press; What's 10 inches about it?? #3
The quill travel is how far it will drill in one sweep.
   / 10" drill press; What's 10 inches about it?? #4
100% correct.
   / 10" drill press; What's 10 inches about it?? #5
...A friend of mine needed to drill some 4x4s, so also bought himself a 10" drill press, & was disappointed to find out a 10" drill press apparently doesn't drill a 10" deep hole. I think it drills a 2.5" to 3" deep hole.
You would need a 10" long drill bit to drill 10" deep holes, actually more like 12" since some of the drill must be in the chuck.
While I have seen some long bits, 10-12" is not going to common.
If he isn't skilled with using a hand drill, he can get the hole going in the right direction with his press and finish up with a hand drill and a long bit...
OK I did that tonight ... & it is 5" from the front of the column (not its center) to the center of the chuck. However, since the 5" isn't from the center of the column, & the column itself has a diameter of 2-1/4", wouldn't the swing actually be more like 12-1/4"? :confused2:
But ... I measured a few other dimensions while I was at it, & happened to find that if I lower the work platform all the way down, the distance from the work surface to the bottom of the chuck is exactly 10".
That's true! Not sure what the heck either of us was thinkin'! :ashamed:
That's what he ended up doing, which is what I've had to do before, too.
   / 10" drill press; What's 10 inches about it?? #8
Coincidence. If it were a floor mounted 10" drill press it would be more like 3-1/2 feet.
   / 10" drill press; What's 10 inches about it?? #9
Take a piece of plywood at least 6 - 8" long and drive against the column and drill a hole in it, now measure from the center of the hole to the edge that was against the column. What do you measure?
Steve
5 inches
   / 10" drill press; What's 10 inches about it?? #12
What is the point of a swing measurement anyway? Other than to know you need to divide by 2 to get the "useful" throat measurement?
X 2 = 10". Are you sure you're not a corporate CEO that just bought his first power tool? :laughing::laughing:
I wish I was a corporate CEO (at least paycheck-wise) ... but I have many power tools.
   / 10" drill press; What's 10 inches about it?? #15
10" in a 10" drill press refers to the width of a board that you can drill a hole to the center of. Cool,
   / 10" drill press; What's 10 inches about it?? #16
Drill as deep as you can go. Stop the drill. Raise the table with the drill bit still in the 4x4. Clamp the table and drill the rest of the way. The depth is limited only by the length of your drill bit. So you can drill 10" if you have a 12" bit!
Next option is again, drill as deep as possible, stop the drill, raise the quill and lift the 4x4 (same as above). Rather than raising the table, slide a 2x4 under the 4x4. Restart the drill and drill the rest of the way through the 4x4.
2013 Dodge Durango (A53317)
2013 Dodge Durango...
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
iDrive TDS-2010H...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
Tug Boat with Tri Axle Magic Tilt Boat Trailer (A59231)
Tug Boat with Tri...
