Backhoe 10 days till backhoe!
/ 10 days till backhoe!
Al -- Unfortunately, poor Ed's hoe sprang a leak the day I showed up! /w3tcompact/icons/shocked.gif Every time he lowered the stabilizers a shot of hydraulic fluid arced thru the air...so we never got to play with it other than to get it mounted (which was a huge help; figured if it was that easy even I could do it!)
I've got a five foot rake I won't need for a couple more months if you need to borrow it.
Pete
/ 10 days till backhoe! #22
Re: Stabilizers..?
Hi I have a 6500 also. In the directions it say's not too lift the wheels off the ground when in use in fact with out a sub frame unless i'm in a low area with tractor and stabilizers are on higher area I can't lift tires with out blocking up stabilizers
/ 10 days till backhoe! #23
Re: Stabilizers..?
I usually end up with the rear wheels an inch or two off the ground. Ditto for the front - I end up with a 3 point contact - the stabilizers and the bucket. Have yet to move the tractor with the 'hoe this way.
/ 10 days till backhoe! #24
Re: Stabilizers..?
I always fully extend the stabilizers. I might let one down a couple of inches to level out the tractor. I find that with the legs down, the digging is much more stable. I did try just barely lifting the tires a couple of times, but quickly found the pads would sink after a few passes with the bucket, and I was back on tires. Digging with just tires on the ground is a bad thing. The tractor is very unstable, plus the load is transferred onto the tractor frame instead of through the legs into the ground.
Now that I think about it a little more, it makes sense to extend the legs all the way from a physics standpoint. When fully extended down, the angle between the ground and the stabilizer is at a minimum. That would cause less torque on the frame.
Kevin
Re: Stabilizers..?
That makes perfect sense to me, but that's exactly what my dealer told me not to do.
Pete
Peterbilt 377 Semi-Truck (A63118)
Peterbilt 377...
UNUSED WOLVERINE TCR-12-48H HYD TRENCHER (A62131)
UNUSED WOLVERINE...
(5) ROLL OF 9'X150' HOUSE WRAP (A62131)
(5) ROLL OF...
Doyle Conveyer with Honda Engine (A63118)
Doyle Conveyer...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
Here are some similar links:
