10-30 or 15-40 oil
   / 10-30 or 15-40 oil #1
dlabrie
Campton, NH
Kubota B2910
I stopped at the auto parts store to buy some 10-30 oil for my B2910. They had a number of brands of oil but they were all 15-40. Is there any problem running the 15-40 instead of the 10-30? Thanks.
David
   / 10-30 or 15-40 oil #2
Your Operator's Manual should list the correct oil viscosities for a temperature range. It should be as a list or in chart format.
For my machine and temperature range, the most applicable oil is 15W-40. Just make sure you get something rated for diesels.
   / 10-30 or 15-40 oil #3
David, the 15W-40 is what I used. Like Roy said, you want an oil rated for diesels. I think Kubota is just a little behind on updating their manuals.
Bird and Roy,
The oil is rated for diesil. My manual shows a range of 10-40. I did use the 15-40.
David
   / 10-30 or 15-40 oil #5
I always ran 15-40 in my other diesels, but it was very thick in the winter. In fact, after running for an hour or so it was still thick. It is not easy to find 10-30 weight oil rated for diesel service (the "C" class) but that is what this 4610 Kubota calls for. After thinking about it for a while, I do not think I was doing my engine any favors running 15-40, since I was running for short (a couple hours) periods in cool to very cold conditions. The 10-30 makes more sense for me in this climate and I feel the engine is getting better lubrication with the thinner oil. If I lived in the south or ran hell for leather in a commercial useage, the 15-40 would be the ticket. The 10-30 oil I use is Chevron Delo 400, and I have to order it from the local jobber since it is not commonly available (but you will find Delo 400 15-40 almost anywhere, and if that is the weight you want, it is an excellent oil)
   / 10-30 or 15-40 oil #6
Isn't Mobil's I's 10-30 synthetic C rated for diesel engines? I know it says it is o.k. for diesel engines on the label.
   / 10-30 or 15-40 oil #7
Yes, Mobil One has a CF rating and has a 10-30 weight. My BX manual calls for 10-30 for most conditions so why not go with a synthetic after the break in 50 hour service?
"I always ran 15-40 in my other diesels, but it was very thick in the winter."
I will change the oil again in the late Fall and put the 10-30 in for winter use. In the meantime, I'll keep my eyes open for a supplier.
David
   / 10-30 or 15-40 oil #9
I've asked this question to every mechanic, farmer and 2 kubota dealers and they tell me to use what the manual for my 7500 says - 10w-30 for all temps, and not to use synthetic until the 150 hour mark. Mobil 1 is the synthetic I will be using. Until then I use the Kubota 10w-30 and I can get it for $2.00 a quart at my local dealer.
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Sakai TS160 TTS5 Pneumatic Asphalt Roller (A49461)
Sakai TS160 TTS5...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2008 FORD F-450 (A50854)
2008 FORD F-450...
