danny77
Hey Guys,
I've been reading all the trailer posts, but still have a few questions.
I'm looking for a trailer for my Kioti ck2610 compact tractor as well as for general homestead use. I want to only have to buy one trailer and have it do everything. I don't have money to burn, but at the same time don't mind paying the price for a better item.
There seems to be a constant theme in the forums to go bigger rather than smaller on a trailer. We have a Big Tex dealer in the area, so I've been checking out their stuff. Think I might have it narrowed down to a 20' tilt in either 10,000 # or 14,000 axles.
So here are the numbers:
Tractor weights 4,600 pounds with FEL and loaded tires.
Truck- 2015 F250 FX4, trailer package, 6.2 gas- GCWR 19,000
Truck, fuel, passengers weigh - 7,000
Factory installed hitch is rated 12,500
assuming loaded trailer is max of around 10,000 then my tongue weight would be max of 1,500 pounds.
If I'm understanding things correctly, at this point the most a loaded trailer can weigh (for my truck) would be 10,500 pounds.
So I'm looking at a Big Tex 14TL 20 foot with 14k axles (14,000 GVRW). It's a partial tilt 16 foot, with 4 foot deck. It weights 3,500 pounds which leaves me with a cargo cap (based on my truck) of 7000 pounds. This is well below the trailers max rating of 10,500 pounds of cargo.
I like things to be heavy duty and under-stressed. If I don't mind the extra cost would I be better off going with this 14k trailer or go with a 10,000 GVRW rating in the same trailer with 10,000 axles (Big Tex model 10TL-20). That trailer weighs a bit less at 3,150 pounds, leaving the trailer with a max cargo cap of 6850 pounds (which is about the most cargo I could put on it anyway with my particular truck)
So what do you guys think?
Also, am I on the right track thinking that a tilt deck will make things a lot easier than non-tilt? I saw they also make a full tilt 20', but I thought the 4' of non-tilt deck on their partial tilt model might be handy to have.
Thanks in advance for your input.
