#1 diesel or #2
   / #1 diesel or #2 #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I just went and got some #1 diesel for my tractor. Can anyone tell me the difference between #1 and #2 winter blend other than #1 is $ .25 cents a gal. more? The attendant at the station did not know and neither do I.
   / #1 diesel or #2 #2
Viscosity and volatility.
#1 (aka kerosine over here) is 28 seconds viscosity and is more volatile than the # 2 (aka fuel oil) with 35 seconds viscosity.
I think #2 plus additives (winter blend) just prevents waxing - it does not increase volatility nor reduce viscosity.
J
   / #1 diesel or #2 #3
I've always thought #1 was very close to Kerosene but with a lubricant in it. Kerosene doesn't have as much power as #2. Not sure if #1 is the same powerwise to #2.
   / #1 diesel or #2 #4
These days kerosene and #1 are the same-cloud point about -40.The bulk plants don't want to stock more products than necessary.Lubricity will need to be added to kero/#1 to protect your fuel system. Better stations will provide blended fuel with additives(think Holiday)to reduce cloud point and improve lubricity.ULSD has a cloud point of 4-9F on the average.Good Luck!
   / #1 diesel or #2
From what you guys are saying, I should use # 2 year around. There's no advantage of using #1.
   / #1 diesel or #2 #6
Only advantage to #1 is gel point. It doesn't gel unless temps go a lot below -40 F/C. You can get enough protection against gelling either by using an additive in #2 or by using 30-50% #1 in #2. Fuel use is less for #2 because it is heavier and has more BTUs.
Ralph
   / #1 diesel or #2 #7
I explained that the station right down the road from me was selling on road; taxed diesel for $3.10 a gallon.
1*I'm rather confused as to how not paying roughly $0.40 cents (or so) in road tax and buying in somewhat of a bulk purchase warrants $0.30c more per gallon than taxed on road diesel at the pump.
2*I have to wonder about dyed #2 being more expensive than taxed, non-dyed #2. That just doesn't make sense to me. Anyone else notice anything like this?
1*It doesn't warrant it.
2*That dealer's padding the price
Just speculation on my part, based on casual observation.
I assume that sellers use a last-in, first-out (LIFO) pricing policy; i.e., they set their retail price based on the wholesale price of their latest inventory replenishment.
3*When wholesale fuel prices are increasing, high-volume sellers would increase their prices faster than low-volume sellers because they replenish their inventories more frequently.
Steve
3*I don't think that is the case here.
4*How much would it cost to hire a truck driver to drive to another jobber and deliver 700 gallons to you? Probably less than $280.00 (700 x .30).
4*Good idea.
I bought some #2 dyed deisel to put into my fuel oil tank at the farm for the Oil heat last friday. I purchased at Saluda Oil Co. In Saluda SC. They sell fuel oil and deliver it. I have a tractor truck service business and do tires all there. I paid $2.58.
5*I wish i had more capacity than the 2 5 gallon cans as all the talk its going up makes me wish i had bought more like 75 gallons.
By the way those of you that say that the dyed is the same as the pump and is ULSD.
6*At least here in SC its not.
7*This is the second fuel dealer who has told me off-road is LSD.
8*The fuel oil receipt they gave me listed 10 gallons of #2 dyed Low Sulfer Deisel.
5*You must be in one ot the 5% areas.
6*I keep a few extra 30 and 55 gallon drums around for that.
7*You must be dealing with a co. that hasn't used up or sold all their Low Sulfer Deisel because they aren't makeing any more of
8*They might it be using old sales receipts.
9*All 3 suppliers I've used all said they had to move to ULSD the first of this last year.
These suppliers are either not wanting any orders less than a thousand gallons
10*or they are just flat stabbing customers on the price.
but
11*now it's the principle of the suppliers making a killing per gallon!
9*That's cause they no longer make LSD.
10*That's it.
11*Something is fishy here.
12*Maybe my memory is bad, but it seemed like it saved me at least 50 cents a gallon, if not more, compared with filling 5 gallon cans at the gas station with on road diesel.
13*I guess that's my problem;
14*I can't figure out how it's the same price for non-taxed, dyed off road use only diesel as it is for diesel at the pump that has a road tax already added to the price.
15*It just doesn't add up in my mind.
12*Nothing wrong with your memory nothing at all.
13*No you don't have that problem
14*That's cause it don't figgure.
15*It don't add up period.
   / #1 diesel or #2 #8
4*Good idea.
10*That's it.
What??? I think you had 2 threads open at the same time and posted this response to both. This goes with Dargo's post.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2013 TIGER CAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGER CAT...
