1/4 inch - vs - position control
   / 1/4 inch - vs - position control #1
coldstream
NW MO
I'm looking at a range of brands and models and am wondering how significant the difference between these 3 pt controls is. I would think that the position control would offer a more fine-tuned control but I wanted to hear some opinions of those with experience. Obviously I'm consider the Kubota B series which has 1/4 inching valve with the Bobcat, the JD and the Kubota L series which offer the position control. And, yes, I did a search back into late '09 and saw no obvious threads where this had been specifically discussed. Thanks for your input!
   / 1/4 inch - vs - position control #2
P C makes tasks like finish raking,cutting,blading,much easier and more precise. P C is like power steering, if you have never owned it, you dont know how nice it is. Once you have owned it, you cant go without it! Well worth the $$$ imho!
   / 1/4 inch - vs - position control #3
Precise increments of lift as controlled by the position control lever are really only important if you are doing something like very fine finish grading in a landscape application. There are pros who want increments of lift of as little as 1/8" at the blade of a box scraper to achieve their objectives. Most of us aren't capable of utilizing such precision, and most tractors don't have it either.
   / 1/4 inch - vs - position control #4
I have a Kubota B7800 with the quarter inching 3pt. control and a Grand L with position control and if there was some way I could retrofit the B with PC I would. If you are going to do much work with your 3 pt. I would recommend position control.
   / 1/4 inch - vs - position control #5
I have to disagree, with a position control 3 point hitch I can lift the back blade, tiller, hayrake or whatever I have back there, turn around and drop it back in place WITHOUT having to look at the implement.
I dont care about 1/8", but when raking hay (for example), I need to keep the rake in that "sweet spot" between digging into the ground and not picking up all of the hay. I can do that all day long on the L3830 that has position control. I cannot do that on the B7510 which has a 1/4" valve. With the B7510 I have to fuss with the height in every row, this cuts into my speed and how well I can rake the hayfield.
Aaron Z
   / 1/4 inch - vs - position control #6
I have both an L and a B series. I read a lot about the 1/4 inching valve be- fore buying the B7800 and to date am fine with it. I till with it (all the way down), 3PT forks (up and down) and a little blade work. Nothing that requires repeatability. You do have to hold the lever until it is where you want or tap to get the inching effect. Personally I adjust the flow control and just use it normally. Whenever a Human is coupled to a machine the Human needs to program the brain to the parameters of the machine to obtain optimal results. Anyone that has done repeatable production work can attest to this, especially when the process changes and a reprogramming is necessary. Soon all these tractors will come with a remote control and seat time will end, then what will we do?.............................;)
   / 1/4 inch - vs - position control #7
I suspect that they're near the same. No one seems to have explained technical differences yet for you.
I'd love to have it to position the front of the brush hog on my 4010 without having to allows look back there when I drop it. My 4010 will technically do it, but the range of motion on the jack shaft is not precise enough to get the lever in the same position all the time. The newer (2320 and 2520) JDs have a MUCH longer range of motion at the jack shaft, with more markings.
I wonder on those whether my knee cannot bump the lever like it does the joy stick. Think they have a positioner that can be moved and locked in position to keep this from happening?
Ralph
   / 1/4 inch - vs - position control #8
I am one of those who would pay about anything to have position control. Yes, I can live without it, but working with any 3-point implement is much easier for me with position control.
   / 1/4 inch - vs - position control #9
Me too! On my little old B6100, the 3pt has two positions - up and down. Yes, I can control the speed it drops with the flow control - and fiddle with it to set it at a certain height. But when I get a full box / rake / blade and come to the place I want to spread the load - uh-uh. Select "up" and rhw 3pt comes all the way up - now. The flow control doesn't control the "up" speed.
So I can't really "spread" the load - it just dumps. :(
   / 1/4 inch - vs - position control #10
I've always used a set of chains to keep my height the same on my tractors with the 1/4 inching valve. There is a bracket that that attaches along side the lower 3pt arms on the implement pin and a chain going up to the pin that holds the toplink to the tractor. At the toplink mount there are two more brackets that have a hole big enough for the chain to go through and a slot to slide the chain down in. That way once you get your initial height set... you can raise and lower as much as you want and it will go down to the same spot every time. Still a bit more work than position control but it achieves the same thing and it also takes the stress off the hydraulics and avoids "dropping down" as all 3 point hitches will do after a while... new tractor or not!
1992 MACK RD688S KILL TRUCK (INOPERABLE) (A53843)
1992 MACK RD688S...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
LOT LOCATIONS (A54607)
1992 SHOP MADE CHASSIS TRAILER (A53843)
1992 SHOP MADE...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
