1-1/4" 19-spline PTO Yoke?
   / 1-1/4" 19-spline PTO Yoke? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Any idea where to get one?
Working on a JD number 9 sickle mower that is missing the PTO shaft. The input to the mower gearbox is 1.250" OD and 19 splines. No thru-hole but but has the radius groove for like a quick attach style.
Every big MFG that I have looked at their parts lists and PDF's for dont even show this spline as an option.
Deere parts online show a part number of 22202h but that comes up with nothing
no picture and no description to confirm its the right size either
I'd get an 1-1/4 round shear bolt type and drill a hole before I spend more than a whole pto shaft will cost
   / 1-1/4" 19-spline PTO Yoke? #4
I got the same problem with JD 39n sickle mower. I was wondering if a "Weasler Implement Yoke, 1-1/4 in. Round Bore with Keyway & Set Screw" from tractor supply would work? Any thoughts?
   / 1-1/4" 19-spline PTO Yoke? #5
Not sure about the sickle bar, but I useda weasler shaft and yokes to match to a JD pin on yoke and the original yoke on the 709 bushog and it works fine.
   / 1-1/4" 19-spline PTO Yoke? #6
Not sure if you have resolved this yet, but 1 1/4-19 spline couplers that weld to a 1 1/4 shaft are available at most dealers around here to use when making a new snowblower side shaft. The coupler tends to be around $45 Canadian. I would think it would then be possible to put a short piece of shaft in and put a yoke on.
Thanks. It's not been resolved yet. It's. It real high on the priority list right now. No need and no use for a sickle. Just looking to fix and sell eventually
   / 1-1/4" 19-spline PTO Yoke? #8
I want to say the correct part number is most likely H30438 used on a bunch of other things like sickle mowers 37, 38, 39 and model 350&450....... just a good guess
AGT MX15RX Mini Excavator (A44501)
AGT MX15RX Mini...
2019 ALLMAND BROS, INC. LIGHT TOWER (A45046)
2019 ALLMAND BROS...
Club Car Carryall 1500 4x4 Utility Cart (A44572)
Club Car Carryall...
Bushog 6ft Disk Mower (A44391)
Bushog 6ft Disk...
2019 WYLIE HYDRO EXCAVATOR TRAILER (A45046)
2019 WYLIE HYDRO...
2014 FREIGHTLINER CASCADIA (A45046)
2014 FREIGHTLINER...
