'06 ZD28 - Steering Adjustment
   / '06 ZD28 - Steering Adjustment #1
millwoodva
Millwood, VA
Kubota ZD28
Just purchased a ZD28 (1150 hrs. with recent hydro kit mod.) yesterday.
To drive in a straight line, the right lever must be pulled back slightly..
Is the adjustment a simple task..?
No manuals were included with the sale, so I'll order them soon.. Thanks..!
   / '06 ZD28 - Steering Adjustment #2
If you'll pull the seat up - pull back catch directly behind seat before lifting. Now you can see a linkage on each side (spherical rod end attached to threaded rod with jam nut). To adjust loosen jam nut and turn hex on rod - sorry but cannot remember which way does what. I can tell you a complete revolution is quite a bit of difference. Good luck with it!
Thank you Sir..!
The day following my post, I began to look for the source and it was quite clear after raising the seat...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
