Loader '06 JM354 Jinma TL-20 Loader Valve Leaks (old style)
   / '06 JM354 Jinma TL-20 Loader Valve Leaks (old style) #1
bjr
Veteran Member
Eastern WA
Jinma JM354
The seal around the valve spools leak and a cylinder hose outlet port leak. I've looked on line and there doesn't seem to be a seal kit available for them. I've seen $600 complete replacement valves, but that seems extreme for a small spool leak. Please tell me what is available to repair these valves. I'm hoping to find whatever o-ring repair that is needed. bjr
   / '06 JM354 Jinma TL-20 Loader Valve Leaks (old style) #2
they are just orings in valve,metric,I got mine from a friend that had all sizes,I believe harbor frieght sells a kit of metrics,valves are simple to rebuild
I haven't taken the valve apart yet and would like to have the parts setting in front of me when I do. The spools have some kind of plastic/bakelite sleeve sticking out just underneath the control linkage and I would like to get those sleeves. Have you actually had your valve spool out? What kind of sleeves/wiper seals are in there? Having said that do you have a parts book with a break down picture of the valve body? I may even already have the HF metric oring kit in my tool box. bjr
   / '06 JM354 Jinma TL-20 Loader Valve Leaks (old style) #4
mine was a 05 model,stick is straight up,they are simple in design,all I did was clean and install new orings through out valve body,had to use allen wrench to remove spools
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Syrup Kettle (A50123)
Caterpillar 200 Forklift (A53117)
Caterpillar 200...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
