'05 gt 1554 belt problem
   / '05 gt 1554 belt problem #1
hfdff
TX
2001 New Holland TC33, CubCadet gt1554
The belt on the deck keeps popping off after mowing for awhile. I replaced the belt last year due to it popping off and it seemed to solve the problem for awhile, now it has started all over again. Here's some of the symptoms I'm having: at startup the belt seems as though it is real loose just flapping away even when I engage the blades. I checked the spring length but not sure where exactly to measure. I did notcie some play in the idler assy. but not much. I compared the belt to a new one and it seemed to be the same. Dont want to spend another $80 bucks on a new belt. I ordered a new spring and I'm going to try that out Just want to see if anyone had any other suggestions and to if this is a common problem.
   / '05 gt 1554 belt problem #2
Belt should have tension on it at all times; belt is started with clutch system. This seems to be a problem with many of the 1000 series machines. I have heard that CC has added another idler pulley to newer mowers (NOT SURE). I would tighen the idler spring a little by drilling a new hole for spring holder/bolt. Be careful not to overtighten as bearings become an issue. You may also want to add belt guides by the pulleys to keep the belt in place. 1/4" rod bent like a letter "L" with a loop at the bottom of the "L" to put a bolt through it to hold it in place will work. Good Luck.
I have found that if a belt looses it shape from slipping off it gets a "memory" and continues to slip off and will need replacing. Hopefully you can remidy it quickly.
thx for the suggestions when I go pick up the new spring I'll check to see if they have some type of retro fit for a 2nd idler hopefully they do and thx again.
   / '05 gt 1554 belt problem #4
I have the same problem. My local service guy contacted Cub Cadet on this and they actually recommended bending one of the pulley brackets so the angle of the belt (in relation to the pulley) is not so severe.
A couple of other things that have caused the belt to pop off:
  • Worn belt, gets to flopping around so bad it will pop off the pulley
  • Cutting height set to low (the lower the deck is set, the more severe the angle to the pully)
   / '05 gt 1554 belt problem #5
If the previous posts don't solve your problem, I think there were a bunch of posts about this last summer during grass cutting season. I bet you can find them using the search feature. It's a great feature that you find a lot of information with. Good luck.
   / '05 gt 1554 belt problem #6
Just a side note, i bought a new OEM-MTD/Cub deck belt for my SLT 1550 at Lowes for $38.
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
Vermeer 840 Discbine (A50774)
Vermeer 840...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
Road Drag (A50514)
Road Drag (A50514)
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
