05 CK30 hydro foot lever too stiff
   / 05 CK30 hydro foot lever too stiff #1
TerryRS
2005 CK30
Hey Guys, My issue with my Kioti CK30 is pretty much explained in the title. I've removed the self-centering device along with the spring-loaded doohickey next to it which helps a bit but definitely not the issue. The foot lever rotates two shafts extruding from the trans. The rear shaft seems to be ok -- because of a bit of play the shaft seems to move easily to move the tractor. Once the play is taken up and against resistance with the front shaft ( unknown to me what its purpose is), is where it seems to have the problem. I can take both hands and rock the foot lever, but the front shaft seems to be the culprit of too much resistance (if I use my foot to push the lever forward it will actually bend it). I've tried spraying lubricant but it doesn't help. Any other suggestions or ideas are much appreciated --Thanks!
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
