maddmechanics
- Joined
- Dec 16, 2021
- Messages
- 3
- Tractor
- 04' New Holland LB75.B backhoe
I've recently acquired a backhoe that's been sitting for a year, possibly longer. I went ahead and removed and cleaned fuel tank, new filter, new batteries, fresh fuel ect.... It will turn over and I even had it running, for about 2 minutes. And I got it to start several times, but it would just stop. I have bled the lines and it holds pressure all the way to my primer pump. I bled the injectors and it'll start right after I do, but then it cuts off and I have air at my injectors again but not at my primer pump. And it goes back to not starting and now it won't even start after the injectors are bled. I'm just at a loss on what to do next. I really just need it moved to my shop but I can't get it to run or lift buckets. Any help would be greatly appreciated. Thank you.
