meathouse
I have a 03' B21, I was using the 3-point hitch to do some box bladeing the other day, about 20 min of use the hitch would not come off the ground. I have plenty of hydraulic fluid
in the system, if anything it is over full from removing the back hoe with too many cylinders compressed. I have rotated the knob between the seat in all directions, and ensured
the valve that is either up or down for either back hoe operation or 3-point hitch appears to be working correctly. When trying to lift the 3 point hitch, the hydraulic line loop moves ever so slightly like it is trying to lift, just with very little or no force. I have not tried to remove the box blade yet to see if it will lift with out any load. Any suggestions would be a huge help.
