'03 2810 PTO Lights up but won't Rotate
   / '03 2810 PTO Lights up but won't Rotate #1
mbaker
Mahindra 2810
Hi, I recently hooked up my auger, pushed the PTO button, and it lit up but no rotation. I also tried switching the Manual-Off-Auto selector switch but no go. It's been a while since I've used the PTO, and I think this has happened before, where it didn't work, and then after a while it worked! Should I open up the dash and wiggle and/or clean some connectors, or on the firewall? About a year ago I could not start the tractor, and finally took it into a shop, and they found a connector under the hood on the firewall needed cleaning - that was all! Is the PTO solenoid under the dash covering, or where would I find it? The fuse on the firewall for "Key Stop/PTO" seems to be good; runs ok.
   / '03 2810 PTO Lights up but won't Rotate #2
If possible, check for voltage at the switches and solenoid and that the solenoid is grounded still. It's probably an electrical issue.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2011 DODGE RAM 2500 (A50854)
2011 DODGE RAM...
