02 4110 clutch noise
   / 02 4110 clutch noise #1
cdude
I just replaced a bearing in the pto and put it back together then used it for 3 hrs mowing. It started making a whining/growling noise when I pressed in the clutch. It got worse as I used it. So I took it apart again.:mad: everything looks good. I hate to put it back together without finding the problem. Any ideas?
   / 02 4110 clutch noise #2
posibly the pilot bearing is starting to go i had would make noise a while back, if you have it split, try spinning the pilot bearing, look for signs of rust, also make shure the pilot bearing is installed in the flywheel not the crankshaft. also release bearing posibly
thats what it was. I just assumed the pilot bearing went in the crank not the flywheel. thats a little unusual. thanks for your help. You saved me from committing ins fraud and my tractor from a firey death.
   / 02 4110 clutch noise #4
Glad I could help and your back up and running.
   / 02 4110 clutch noise #5
Would this solution be the reason my s370 beaver satoh does exactly the same thing? Thanks
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
