#00 gear grease
   / #00 gear grease #1
dqdave1
Veteran Member
N. E. Ohio
tc- 29d
What is and where do I find #00 gear grease
   / #00 gear grease #2
NGLI #00 is a viscosity. The standard stuff you buy to do your tractor and vehicles is normally NGLI #2. #00 is what is considered a semi-fluid grease (very thin) and is often used as a gear box lubricant in place of gear oil.
Most lubricant manufacturers make a NGLI #00 grease. What are you using it for? Two excellent NGLI #00 greases are TRC's 880 Crown and Chassis grease and Millennium 2200 grease. The Millennium 2200 also has Moly and Graphite added as a solid film lubricant additive. For gear cases I recomend the Millennium 2200.
   / #00 gear grease #3
Of course DP is right on.
Depending on your application.. JD's cornhead grease ( used for the neames stated purpose ) may suit you.
Soundguy
   / #00 gear grease
It is called for in the chain drive gear box of a Harley Power Rake.
   / #00 gear grease #5
The Millennium 2200 would be perfect for a chain drive gear box application. The chain would greatly benefit from the Moly and Graphite lubricating properties.
   / #00 gear grease
Thanks for your expert advise; I knew you would answer me with information.
Next question; where to buy it.
   / #00 gear grease #7
Click the link in the above post, the site is mine so the contact info on it is directly to me. :)
   / #00 gear grease #8
Hi,
Found a good resource for all kinds of stuff tractor folks might need. Check out Applied.com. I can get a Qt of Lubriplate Mag-00 Series Low Temperature Grease for about ~$20 or a gallon for ~$60. Applied tech has 400 locations all around the country and you can mail order on the net too.
Been searching for EP-00 or NLGI 00 semi-liquid grease myself and yeah it's a pain. This stuff is made for leaky gear boxes or pumped central lubrication systems for heavy equipment and ones that are gonna leak due to cheap / poor design. I've got an earthquake rear tine tiller that specified "Mystic 00 transmission fluid PN 1690"
Another problem I've encountered is packaging size. I really don't need a 55gl drum of goo costing more than the equipment I'm repairing. I found my fix and offering it up to help you save some time and equipment. This stuff should be great for weepy PTO gear boxes and Applied may be a good source for bearings, bushings, and seals to fix'em too.
Hope this helps
   / #00 gear grease #9
Schaeffer greases perform at least as well as Lubriplate and are less expensive. You can get the #00 grease in cases of tubes. Go online to schaefferoil.com. click buy now, choose high performance grease. the 0274 comes in a 30 tube case for $158. coupon code 2762 will get you a 10% discount. Or you can find a Scheaffer guy in your area. Its worth the effort.
   / #00 gear grease #10
jd cornhead grease is 0# and ep.. can be had at JD parts counters by the tube ( or perhaps by the case in some areas ).
soundguy
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2007 STERLING A9500 TANDEM AXLE DAY CAB (A43004)
2007 STERLING...
2017 Ford Explorer XLT AWD SUV (A42744)
2017 Ford Explorer...
2013 Komatsu D39EX-23 Dozer (A42203)
2013 Komatsu...
2009 Viking Trailers Flatbed Trailer, VIN # 1V9FC44239N062500 (A44391)
2009 Viking...
Year: 2011 Make: Ford Model: Expedition Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A44572)
Year: 2011 Make...
