'00 4200 work light power feed
   / '00 4200 work light power feed #1
KerryK
\'00 4200 work light power feed
I am adding a couple small rear facing work lights to my 4200 - in the owners manual both the fuse panel and light switch list "work lights" entries.
I'm assuming (from other posts I've seen) that the wiring loom has a feed to the ROP area - can anyone confirm this?
On each side there are 3 wires that run up to the tail/turn lights, where those three wires come out of the loom there is a fourth wire (black) that is taped to a lavender wire that goes back into the loom. This is the same on both sides.
I couldn't find my tester last night - so I couldn't probe around on my own. Time to go to HF and buy another one /forums/images/graemlins/shocked.gif
I'm not putting much for lights on it an would prefer not to run a separate feed if there is already a switched/fused feed there (call me lazy).
Thanks all - Kerry
   / '00 4200 work light power feed #2
Re: \'00 4200 work light power feed
I found a wire under the seat, I think it was purple that I tapped into for extra lights. It is hooked to the switch in field possion ( lights on flashers off) hope this helps
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
