0% Financing UTVs?
   / 0% Financing UTVs? #1
Hotwheels
Rescue, Northern California
Kubota BX24, RTV900-Worksite
Kubota and Bobcat both have some ongoing 0% financing deals. Are there any other UTV makers that also have these types of 0% financing deals?
   / 0% Financing UTVs? #3
Deere has NPNI for 6 months.
Looks as if Brush Hog as 1000 off or 0% for 36 months .... there are a few more than I thought. Talked this over with my spouse and we decided not to let the financing deals drive what we do :)
TOMMYHPX4X4 said:
what are you gonna be useing it for. alot of work and a little play or alot of play and a little work or play and no work or work and no play?
All work no play ... to much work to do to play. We live on a hill and there are places I will not go with our Bx24, so we are looking for a machine to spray some weeds, maybe pull a small rake and worst case a mower. Hauling rocks, debris, and cut down tree limbs, and general property maintenance. Seems like a diesel machine may be a good option, but I know nothing about these types of machines.
   / 0% Financing UTVs? #7
ok when you say going places the bx24 won't do you mean muddy places or just plain uneven rocky places? if so you might wanna rethink the mule they are good but they do have a low ground clearance the xuv's are a nice choice the rhino is out for sure because it has trouble hauling 400lbs and when you so the rear shocks give out really fast. from what your descibing i would go with the xuv it has power it can haul a nice load and pull a nice load to . you might be disapointed in the mule if you get into some muddy locations it has about the same clearnce as my hpx and i had to upgrade to some 589's just to go through the mud they pretty much drag the rear diferntial through the mud when it bottoms out. i would rule out the ranger because it's a more play and some work kinda utv it can pull a nice load but i seen them with loads in the bed and the front end points to the stars so you might wanna go see the xuv's the deisel dosn't have a clutch enclosure but the gas model does.
I wish I had mud to deal with, but it is mostly rock with some steeper slopes. The BX24 on about 1/2 my property feels unsafe for me because of the instability from the rocks and slope.
I looked at a Ranger and it seems to have good carrying capacity and towing. I will take a look at the XUVs.
Thanks!
   / 0% Financing UTVs? #9
yes you might wanna take a look at the xuv's they are wider and more stable on inclines compared to the mules plus crossing over rocks and stuff you might need the extra ground clearance i think the xuv will be a better utv for you .
   / 0% Financing UTVs? #10
Ask them to load the ranger with a 1000 lbs(rated capacity) and look at it before you buy it. Do the same with JD I think you'll under stand what I mean. Of the two machines the ranger has more play than work in it and the XUV has more work than play in it IMHO. Sounds like you want to work.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
