B26 TOP-N-TILT KIT
   / B26 TOP-N-TILT KIT #1
SamWalton
Platinum Member
Sallisaw Oklahoma
Kubota B26 TBL
Does anyone know what this kit for the B26 is?
The last part shows "B8039 TOP-N-TILT KIT 50 $ TBA" To Be Announced (TBA). I guess this means it is no yet available, but I sure would like to know what it does and where it goes? Any help? Thanks
You can reference the attached B26 WHOLEGOODS PRICE LIST.pdf
AUXILIARY HYD. VALVE / TOP-N-TILT KIT
B8027 BASE KIT AND 1ST LEVER 16 $ 412.00
For 1st valve. Requires B8028.
B8028 DOUBLE ACTING VALVE SECTION 15 $ 206.00
For 1st or 2nd position.
Requires B8027 or B8030
B8029 FLOAT DETENT VALVE SECTION 5 $ 258.00
For 2nd position only
Requires B8030
B8030 SECOND POSITION STACKING KIT 10 $ 206.00
For 2nd valve. Requires B8027 and B8028
or B8029 valve section.
Includes Cylinders and Hoses
Requires 2 B8028 valve sections
   / B26 TOP-N-TILT KIT #2
Sam,
The Top and Tilt kit uses hydraulic cylinders for the top link and tip adjustment on your right hand 3pt Arm. These cylinders are controlled by your remote valves(if equipped). If you have no remotes, you will need them to operate Top-n-Tilt. The remote valves are the expensive part of adding top-n-tilt.
Landscapers usually get top-n-tilt so that they can tilt and tip their box blade, rake, grading blade etc. from the seat of the tractor, rather than getting off and twisting the arm adjustments. I have top-n-tilt on my new L5740. Is it a must....No, But it sure is handy if you use box scrapers or rakes etc.
   / B26 TOP-N-TILT KIT #3
Sam:
I see that your pricelist still has the B21 prices in it. It seems that
Kubota offers only a 2-spool rear hyd valve setup for TnT on the B26,
instead of the 3-spooler my B21 has. I do not know why they don't
have a price for the cyls in your B26 kit. What does your dealer say?
dfkrug said:
Sam:
I haven't asked my dealer about the TnT but I am tring to learn all the options and uses.
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2020 McLanahan 150 TPH USP Sand Plant (A52377)
2020 McLanahan 150...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
(3) ROLLS OF 4' GLAVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
