‘01 NH TC33D High Pr Relief Valve Weak??
   / ‘01 NH TC33D High Pr Relief Valve Weak?? #1
Mbe
2001 NH TC33D
Bought a used tractor. 1157 hrs. After short time, under very light load, just going up small incline, acts like loses pressure. Replaced fluid and filters. No change.
Tested at test ports and approx 1500-1600 psi seems like relief valve opens. Both forward and reverse. Should go up to 4000+ psi according to repair manual.
Pressure builds up fast when push pedal, but drops to nearly zero when gets to about 1500-1600 psi. No whining or other wierd noises until it gets to 1500-1600 psi.
All pedal adjustments look good.
Could it just be a weak high pressure relief valve?
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
