MF 1533 Hydraulic Oil
   / MF 1533 Hydraulic Oil #1
Gilford
Member
Michigan
Massey Ferguson 1533, syncro shuttle
I am preparing for my 50 hour service, and my MF dealer sold me MF hydraulic oil that is simply labled Permatron. My manual says to use Permatron III. When I questioned him, he said it was the same stuff. I normally wouldn't doubt a dealer, but I haven't been completly impressed with their knowledge in past situations. Has anybody else used MF brand Permatron in their 1533, or did you find MF brand Permatron III?
Thank you,
Gilford
   / MF 1533 Hydraulic Oil #2
They are changing the names of everything to do with parts to the AGCO crap. The containers for Permatran III will all say AGCO Permatran 821XL. Before long, I bet that it will only say AGCO 821XL.
Thanks, I did find AGCO Permatron 821XL on the list of equivalents on the back of the jug. It sounds like I have the right stuff.
   / MF 1533 Hydraulic Oil #4
I don't know if your interested, but I priced the Napa oil at about 1/2 the price of Permatran. I know this varies by region. I checked it out and it meets specs of AGCO Permatran XL 821. No more Permatran III at local dealer, everything's AGCO.
   / MF 1533 Hydraulic Oil #5
It's still Permatran III even though it says AGCO Permatran 821XL. Your bio doesn't tell what transmission your 1533 has. But, if it has wet clutches or a hydro I wouldn't put anything in it other than Permatran. If it is has a dry clutch manual transmission then the Napa oil might be alright.
   / MF 1533 Hydraulic Oil #6
Sorry if I wasn't clear JerryG. I should have said Permatran III is now re-labeled AGCO Permatran 821XL. You are right in it's the same stuff. I didn't know that about NAPA oil, though. It shouldn't give me trouble in a SynchroShuttle, though, should it? I believe I have the dry clutch. I'm not close to a 50 hr yet, but don't want any warranty issues down the road.
   / MF 1533 Hydraulic Oil #7
I'm curious about your statement too Jerry. I recently bought some stuff at TSC that lists Permatran III on its compatability list. I would assume that means that it meets the standards for that oil. I do have a HST and am not willing to risk the tractor to save a few bucks. Could you elaborate on the reasoning behind your recommendation?
Thanks,
Mike
   / MF 1533 Hydraulic Oil #8
Off the subject a little... Can you provide some info on your diff lock lever I saw in you photo album?
   / MF 1533 Hydraulic Oil #9
Fluid clutches and fluid brakes require different additives to make them last. I have seen cheap of brand fluid used in tractors that had these features where the linings disintegrated. The 1533 has fluid brakes, but if it has a SynchroShuttle it has a dry clutch. I know that I would be afraid to use anything but a high grade fluid in any tractor with a hydro, a power shuttle, a power shift, a DynaQPS or with fluid brakes. If a tractor doesn't have any of these then the fluid requirements are far less.
   / MF 1533 Hydraulic Oil #10
Hi,
The moral of the story here, stick with Permtran!! It is worth it.
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
24008 (A53422)
24008 (A53422)
402 (A52706)
402 (A52706)
Year: 2018 Make: Ford Model: Fusion Hybrid Vehicle Type: Passenger Car Mileage: 51,578 Plate: Body (A56859)
Year: 2018 Make...
