Mowing Blades running backwards
/ Blades running backwards #1
DCNMVA
S20
I bought a b7500 with a 60" belly mower last week. It's not cutting grass very well so I look under the deck and I see that the bladed are on upside-down. I ordered a new set on blades from kubota and I put the first one on and I realize it isn't going to cut because the forward edge, as the deck currently rotating, is backwards. I realize now that the blades are on upside-down because the blades are rotating backwards. What can cause this? The previous owner replaced the gearbox on the deck. Is it possible that the gearbox is the wrong one and is the problem? Thanks
/ Blades running backwards #2
Do you know for sure that you have the proper deck on your tractor ? is there and chance that a previous owner cobbled something together ?
I don't know anything for sure. The previous owner gave me the paperwork from when he bought it new and everything seems to match.
/ Blades running backwards #5
Can't you get blades for both clockwise and counter-clockwise rotation? May still not leave a beautiful cut, but might be good enough, depending on your standards for the area you are mowing.
/ Blades running backwards #6
Are there any drive belts on this mower attachment? And if so, could it be that one of the belts was too long or was the wrong one....and so it was put on in a figure eight instead of making a circle between the pulleys. That will cause the blades to spin backwards.
/ Blades running backwards #7
Was the grass previously blowing out of the discharge side?
/ Blades running backwards #9
I think Carl is onto something.
I've seen strange things, but this is very interesting.
/ Blades running backwards #12
John deere gearboxes can be assembled in two ways: drive gear forward or at the back. This provides for 2 possible rotation directions. Maybe your box is generic and came in the wrong configuration. Uncap the ends and reassemble opposite ends.
/ Blades running backwards #13
Oh dear -- DO NOT get into this nonsense. Why does TBN not have a "thumbs down" or 'Bad post' button to press?? Blades on a given model deck only go ONE WAY , correctly that is. Others have mentioned the two most likely problems: 1) There was a screw up when the gearbox was replaced. Maybe mistakes rebuilding or wrong gearbox or who knows. 2) The other possibility is incorrect belt installation. The belt may be wrapping around the drive pully from the gearbox in the wrong direction. Anyway get this rotation direction issue solved FIRST before even thinking about any other issues.
/ Blades running backwards #14
I stand by my suggestion.
/ Blades running backwards #15
It seems like you need some more diagnosis. Stating that the blades are upside down and the confusion about the correct rotation.
Take the time to remove the belt guarding and get the mower up in the air for access. Often there's a sticker under the covers showing the belt routing around the various pulleys.
Start by verifying the direction that it is currently spinning the belt/spindles.
Do your new blades match the blades that it came with?
/ Blades running backwards #16
Do you have the blades on upside down? I honestly never know which was my blades are supposed to spin. When I sharpen mine I do one at a time so I just look at the one next to it on how to mount it. Mine has a mulch kit so no side discharge. I doubt this is your problem but I’m checking. Otherwise most likely the wrong gear box.
/ Blades running backwards #17
I agree with JWR. First thing is to determine and rectify if wrong, the spindles direction, to agree with the mower deck and exit chute design
/ Blades running backwards #19
Gear box would be first thought especially since it was changed.
Agreed.
Twice, after buying brand new rotary cutters from a major, well-known manufacturer, I discovered that one or more incorrect gearboxes had been installed at the factory resulting in blades rotating in the wrong direction.
Yes, everything corrected under warranty, but annoying, nontheless.
/ Blades running backwards #20
"Previous owner changed the gearbox":
The fix:
Upside Down Gearbox: If you have recently removed, repaired, or replaced the mower deck's right-angle gearbox, it may have been reattached upside down. Flipping the gearbox 180 degrees will reverse the direction of the output shaft.
