rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,185
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
46F and cloudy @ 14:00, calling for a high of 47F for the day. Low this morning was 39.4F. Winter Weather Advisory has been issued.
Did not get all that much sleep night before last so just wasn't feeling it yesterday.
Did get the battery charger hooked up on the Cub and let that go all afternoon on the 6A setting.
Then got the stud wall on the south wall tweaked to plumb, studs toe-nailed, and top and bottom plates nailed into the joists and the floor.
After that got a few boxes placed and the 3/4' spade bit sharpened up and the holes drilled for the wire for the outlets.
Got another outlet pulled off the west wall after figuring out which breaker it was on.
Whichever goofus that wired up that outlet ran two 12-2 Romex wires down to the outlets in a 1/2" conduit ... without bothering to remove the outer sheath ... which chewed up the outer sheath and made getting it apart a PITA ...
Have wiring for another outlet on that wall that I need to pull out of conduit ... once I figure out which breaker it's on.
First thing on agenda for today though is to see if I can get the Cub started and if not push it to a better location out of the traffic pattern.
Then back down to the utility room.
Hope everyone is having a decent Saturday ...
