• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Just purchased my Summit tractor and flashers and turn signals do not work
   / Just purchased my Summit tractor and flashers and turn signals do not work #1
Triple 5423
Summit TX25H
Just wondering if anyone here has had a problem with the flashers and turn signals, I am guessing it is a relay or a fuse I am just looking to see if anyone has had similar issues?
   / Just purchased my Summit tractor and flashers and turn signals do not work #3
If the tractor is new it is indeed a dealer problem. If you bought it used it gets more complicated. I'd start by replacing the flasher itself.
   / Just purchased my Summit tractor and flashers and turn signals do not work #4
I,m guessing it is a fuse. Do you have a test light, and know how to use it to check all the fuses ? A very quik and easy test, if you are familiar with using a test light. Also, make sure all the fuses are fitting snugly in their position. Sometimes, the female side loosens up enough to cause problems.
   / Just purchased my Summit tractor and flashers and turn signals do not work #5
i would check fuses/relays and voltage at both when engaged.
Fuses are all good.
   / Just purchased my Summit tractor and flashers and turn signals do not work #7
Take it back and tell them to fix it, or give you your money back!
Yeah the tractor is 4 hrs away from the dealer I just need them to send me a Flasher unit.
   / Just purchased my Summit tractor and flashers and turn signals do not work #9
I am not absolving dealers/OEMs of any responsibilities but if I was sure it is the flasher unit that has failed and I am four hours away from the said dealer, I would either email the OEM to get them to send one or just go to the local auto parts store or Amazon website and just buy one.
Flasher units and simple things like that shouldn't fail immediately but most electrical parts are one click away from total failure, even when new on the shelf.
   / Just purchased my Summit tractor and flashers and turn signals do not work #10
Do you have any lamps on the same switch working? In any case, look at the switch also. If accessible, check to see if any connectors are disconnected.
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
2018 NISSAN Sentra (A56859)
2018 NISSAN Sentra...
Ad bottom of page
