Spray On / Rinse Off cleaner and degreaser.
   / Spray On / Rinse Off cleaner and degreaser. #1
homey53
Rutland, VT
Kubota RTV 900, 2016 Kubota BX25 DBL
Not sure I'm in the right Forum for this, but I'm just looking for suggestions for a spray on / rinse off degreaser. Getting towards the end of mowing season here in Northern New England and looking ahead to preping the mower deck for winter storage. I noticed the other day that I've got grease thrown from the pulleys all over the top of the deck. Then the dust cakes on to the grease, and you got a messy deck. I can clean it with Simple Green in a 50/50 water mix, and a spray bottle with a lot of paper towels. Getting older and lazier, I was hoping someone might have the low down on a spray on / rinse off cleaner for such purpose (s).
   / Spray On / Rinse Off cleaner and degreaser. #2
I use green cleaner, or purple cleaner with a 2 or three inch cheap brush. Rinse with garden hose or pressure washer. I have no magic steam gennie for hot water washing. I will use mineral sprits for some gunk cleaning.
   / Spray On / Rinse Off cleaner and degreaser. #6
Get some B52. The best degreaser I've ever used. It worked on my 92 Komatsu track hoe.
   / Spray On / Rinse Off cleaner and degreaser. #7
I would not want to use water on something, I'm putting away for the winter.
Moisture contributes to oxidation.
I would prefer to use an oil based de-greaser, or kerosene to remove grease, and oil.
Thanks for all the replies and suggestions. I would thoroughly dry it out after cleaning for storage.
   / Spray On / Rinse Off cleaner and degreaser. #10
My friend gave me a used and abused Gator. Decades of oil ans dirt in the engine bay. I used Gunk foaming engine cleaner. Sprayed it on, waited 5 minutes and hosed it off. This stuff was magic!
TAKEUCHI TS50R SKID STEER (A52706)
TAKEUCHI TS50R...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
Sunflower Yard Decoration (A55758)
Sunflower Yard...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
