Looking for a new tool, 4lb sledge replacement, power tool option?
   / Looking for a new tool, 4lb sledge replacement, power tool option? #1
JCoastie
Coastal AL
LS MT240HE
I know my wife shouldn't use the zero turn like a bush hog, but she does, and that isn't going to change.
Occasionally the inner deck baffle gets bent and the blades hit it, so I jack up the deck, get on a creeper and beat it back into a reasonable shape with a 4lb sledge hammer since that's all the room I have under there.
I'm getting older, and it's starting to kick my ass. Is there a power/air option that might help me out? I've never used an air hammer, would that work?
Any other options?
   / Looking for a new tool, 4lb sledge replacement, power tool option? #2
Occasionally the inner deck baffle gets bent and the blades hit it, so I jack up the deck, get on a creeper up and beat it back into a reasonable shape with a 4lb sledge hammer since that's all the room I have under there.
Any other options?
Air hammer? no.
Probably best for you go to a lighter hammer.
or
Tell your bride to knock off the nonsense
   / Looking for a new tool, 4lb sledge replacement, power tool option? #3
Pipe wrench with handle extension pipe. But, you'll only get to 're-configure' it a few times until it leaves home. Why not just raise the deck height a notch so it doesn't get caught on the WELL COVER again ???
   / Looking for a new tool, 4lb sledge replacement, power tool option? #5
A large Slide Hammer.
Patrick
   / Looking for a new tool, 4lb sledge replacement, power tool option? #7
Porta-power with lots of extensions and heads will be your friend.
   / Looking for a new tool, 4lb sledge replacement, power tool option? #8
Any other options?
Raising the mower deck an inch would help. Mowing a little higher beats tearing up your mower. The blades will last longer too.
   / Looking for a new tool, 4lb sledge replacement, power tool option? #9
How easy is it to remove the deck on your mower? If you can do that, it would vastly improve your access if you could flip it, perhaps on soft grass.
   / Looking for a new tool, 4lb sledge replacement, power tool option? #10
My go-to tools for forming metal are...
15" Crescent wrench
24" pipe wrench
36" pipe wrench.
Slip the jaws over the bent part, tighten the jaws slightly and bend in small bites until straight.
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
2015 Chevrolet Silverado 3500 Knapheide Service Truck (A55973)
2015 Chevrolet...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
