'24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower
   / '24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower #11
Everyone has different tastes, experiences, requirements, etc. Think it through and get what you really want. This is my 5th (and favorite) tractor. Since the end of 2018 it has been my Swiss Army Knife. It's more user-friendly and easier on the grass than my smaller tractors were. Plows snow without chains or the concrete barrel I thought I'd need. Lifts heavier things than I need to deal with. It mows close enough to things that the DeWalt 20V string trimmer does the trimming without fully discharging a 5AH battery. At 76 it'll likely be the last tractor for me:)
The concept of a tractor doing grass mowing, snow blowing and fel work has always been a misguided one imo.
One has not only be wired for patience of exchanging these implements but also have the physical prowess to be able to do so.
Sales hype is one thing, practicality is still another but the mental and physical part numbers have to match the practicality
LOL I can still hope. I haven't given up yet.
I'm still undecided on whether I agree with the Misguided opinion in terms of being able to effectively apply all those functions yet?
Maybe for some? Maybe not for others. Both users and machines. I think my misguided part was expecting the mower deck ease of mounting dismounting to not affect the mounting of a front snow blower, ALA the TYM/RK/Mahindra etc SCUT.
A ton of people drop belly mowers and use an FEL, then pick the mower back up and think nothing of it. I'm certain I'm not the only guy that can drop an FEL, mower then install a snow blower and soft cab with terra grips on the tires in less than an hour. A SCUT with small implements isn't that tough. Well, I am complaining more as I get older.
After seeing the new 1126 yesterday, I was extremely impressed with the engineering. I dropped the deck off and put in back on twice. I did that in less than 5 minutes. Heck, my wife near effortlessly dropped the deck and with a little coaching put it back on herself once. That whole porocess took 5 mintues or less for her.
I've been swapping implements for the better part of 25 years. Using the same machines for mowing and snow blowing and front-end loader chores without issue.
I've found that having three separate machines to maintain and store and jockey around has been a more time-consuming issue than swapping implements. At least for me. Small property limited storage and workspace. Three aging machines all needing attention, extra vehicles, and various toys all vying for maintenance, just when you need them. (I do keep a walk behind track drive snow blower, in the event the tractor goes 10-7.) Grass mowing and FEL work doesn't shut me down if I let it go by. Keeping a driveway accessible, is a must for me.
The implement swap from mower to blower on the Emax used to be fairly painless. To be honest it still is until it takes two hands to get the PTO shaft on the mower snapped in place. (I might just fabricate a tool for that purpose.) Thus, my keen interest in the quick attach Mahindra mower.
On a side note, all the internet talk of the mid mower not raising high enough has to do with the backhoe sub frame installation. All the 1100's without a hoe, transport at around or above 4 inches. I measured a handful of them.
I think my misguided part is in applying the sales hype to my experience with the TYM built machines implement swap interface. I was hoping that I can easily pop the front snow blower on and off without doing anything other than dropping the mower deck, just like the TYM machine.
   / '24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower #13
Does anyone have any experience with the Mahindra 1100 series? I'm seeing what I think are a few descent prices on left over 2024 models around $19k without the snow blower.
BUT.... I'm starting to see some people having belly mower issues on other forums.
I own a 2019 Mahindra Max-24…., similar to your reference. Your referenced model was designed to be lighter (ladder frame vs tractor frame) along with other components. The belly mower on mine weighs 400lbs, while the 1100 is 200lbs, so greater caution needs to be used to avoid damage.
Everyone has opinions, but Mahindra is a great choice. I’ve owned mine for 6 years without any issues. Great Mitsubishi motor, solid HST transmission, and not as gimped with the usual emissions hardware.
I think you may be paying a bit more than asking, but you could do worse.
Depending on what you’re going to use it for, should determine whether this one, or something larger is best. Always better to determine the tasks needed and the equipments ability to safely and robustly (operating within tolerances) can handle them without destroying your tractor and/or unsafe practices.
Depending on what you’re going to use it for, should determine whether this one, or something larger is best. Always better to determine the tasks needed and the equipments ability to safely and robustly (operating within tolerances) can handle them without destroying your tractor and/or unsafe practice.
I have no doubt you are correct that the 1100 mower deck may not be as sturdy. The mounting points don't look as beefy, though the 1100 deck is actually listed as heavier than the Max 24 deck.
The manual lists the M1154, 54" deck and mounting at 320 pounds. (1100 series)
The Max 24, 60" belly mower manual lists the mower deck as approximately 300 lbs. (Max series)
My eMax20s 50M 54" deck manual lists it at 300 lbs.. (eMax series)
The weights are all very similar. I'm guessing the reason the 1126 deck is heavier than your Max 24 is because of the extra hardware for the self capture system.
I've gotten one dealer response that Mahindra is aware of the snow blower mounting conflict with the mower. Allegedly Mahindra is working on a modification of their design. (Mower or Blower? The sales rep. didn't say.)
This dealer believes the entire belly mower sub frame needs to be removed for snow blower installation. I've got another dealer telling me, that's not the case.
I'm waiting on a response from a Mahindra rep that is researching the issue.
   / '24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower #15
..This dealer believes the entire belly mower sub frame needs to be removed for snow blower installation. I've got another dealer telling me, that's not the case.
I didn't realize there was a subrame required for the MMMs on the 1100s. Sales guy didn't mention this, nor did I notice.
Maybe it was here, but could have been on another site where I read the (lack of) MMM deck height situation is on machines equipped with the BH sub frame. Not sure if that's true or not either.
I've got a copy of the mower deck manuals. I'll try to post it.
I may be using the wrong term. Mahindra calls the parts quick connect mid mount mower linkages. It's a separate mid PTO half shaft that stays on the tractor.
The PDF file is too large. here is a picture of what I am speaking of. Ill try to upload a screenshot. You'll see what I'm calling a sub frame, carriage or quick connect mid mower mount. It's the part in yellow attached to the tractor frame.
   / '24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower #17
With the 100% import tarriff the Trump administration has imposed on India, there must be a helluva markup on them...
The mower deck height adjustment being limited with a BH was me on this thread.
I measured the ones that had mowers on them and BHs and they would not raise as high as the ones without BHs. All the belly mowers that didn't have BHs on the machines raised to 4"s or more.
   / '24/'25 Mahindra 1126 with FEL, belly mower and mid PTO front mount snow blower #20
Good question. Here's the dealer pricing I got a few weeks back on new 2025s
Mahindra 1120 w/ FEL and 54" MMM, $19847. This is out the door, including 8.75% sales tax.
Kioti CS2220 w/ FEL and 54"MMM, loaded rear tires, $18705 out the door.
TYM T224 w/ FEL, 54"MMM, loaded rears, $19170 out the door.
I ultimately purchased a left over 2024 TYM224 from a closer dealership w/ FEL and 54" MMM w/ 2hrs on it for $16200 OTD, but I have yet to take delivery of it as they found an issue w/ the FEL when they PDI'd it and are still waiting on parts. The lower price might account for no tariffs at the time? Dunno.
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
