How much more can a tractor pull with loaded tires?
   / How much more can a tractor pull with loaded tires? #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
I have an m6 and just purchased a 5 bottom plow. I only use the tractor in the snow so I have snow tires on it. I have not gotten to test it yet but suspect traction may be an issue. I have no fluid in. If I filled all 4 tires I expect to pick up around 3k pounds. I am not looking to put the R1's back on. I would certainly think I would feel 3k pounds? This is the first tractor I have ever had not filled. Thanks
   / How much more can a tractor pull with loaded tires? #2
Try it first, then you may want to fill the rears or get some bolt on iron.
Is that a full mounted plow or semi-mounted.
I got to try it on a very nasty patch in my back yard. It is actually a road I put in but needed a place to try it. I have folks asking for plowing once in a great while so picked one up cheap. May never use it. In my yard I could not pull it. I also had a hard time getting it to sink it was so dry and hard. It is a semi. I expect if I got on some decent ground it would be better. I also have none right now to test it on so I said I would ask here if folks ever had anything they could not pull and added weight and pulled it. Putting on the R1's the tractor came with are not an option. 4000 in rims to get set up to pull a plow that may never go out does not make sense. I figure if someone does want to hire me I can add rim guard quickly. I am in an odd situation.
   / How much more can a tractor pull with loaded tires? #4
Is the plow built in a way that you can simply unbolt one bottom? That might be easier than adding weight.
It may be possible but the smaller the plow the less acres it can do so the less I can charge and the price of the tractor stays the same. I can put weight in all 4 wheels for 1500 and right now that appears to be the least expensive way. I think 3000 pounds will make me pull it quite well but wondering how many others have done this. My dealer thinks I can pull it just the way it is if I get on good ground. I think only time will tell but need a plan B in a hurry if they are wrong. I can fill the tires quickly. Beside a little embarrassment I expect the fluid will do it. When I was a kid we pull 5-16 with a 766 2wd. I really need to find a test plot.
   / How much more can a tractor pull with loaded tires? #6
Then why spend the money? Seems like a no gain situation to me.
   / How much more can a tractor pull with loaded tires? #7
Lots of variables with a plow. Soil type, moisture, temperature, blade type, size, sharpness, depth, angle...the list goes on.
Weight over the drive axle should improve traction. The extent to which that happens cannot be answered in a meaningful way.
Also, you may need significant weight on the front end to counter the drag of the plow. I don't know much about your M6, but Kubotas are typically light compared to their competition.
Depending on your specific HP and the soil, etc., you may even be outside the capabilities of your beast. In heavy soil, you can need 20-25 HP per bottom.
Agreed. It is an M6-111. I have something like 1300 hanging on the front now. If I load the rears I am going all in and load the fronts too. I just got a message from a local that has a corn field out back I can play in later.
I didn't spend the money. That is why I asked here what kind of results people have seen.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2005 Toyota 7FGU35 8,000lb. Straight Mast Propane Forklift (A55973)
2005 Toyota 7FGU35...
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
1000000 (A47477)
1000000 (A47477)
Electric Horseless Carriage (A57453)
Electric Horseless...
