Leak at hst input shaft seal
   / Leak at hst input shaft seal #11
To get that bearing out externally, I'm thinking you'll have to carefully use a pick and pry the inner race out, carefully get all the balls out, then pry the outer race out of the bore. Short of that, you'd have to disassemble the hydrostat so you could remove the input shaft out of the bearing, allowing you to press the bearing out of the inside of the front cover.
   / Leak at hst input shaft seal #12
There should be little to no pressure on the back side of that shaft seal. If oil is squirting out I would suspect there are problems deeper inside the HST.
Does that bearing come off the front of that shaft or off the rear. Unusual design if nothing is keeping that shaft from moving inside the bearing.
Do you have a parts breakdown for that HST?
Concern would also be on why is that bearing bad since should be running in constant oil bath and where did the debris go?
   / Leak at hst input shaft seal #13
I'd probably take the whole thing apart and make sure it's clean inside
   / Leak at hst input shaft seal #14
For sure that bearing isn't held in with a snap ring?
As suggested, you pretty much have to search for a parts break down diagram to see how this thing comes apart.
   / Leak at hst input shaft seal #15
Use a pick and pry the inner race out? Then get all the balls out? And I take it you've had success with this method before?
   / Leak at hst input shaft seal #16
Is there a vent in the transmission and if so, is it clean and functioning properly? My simple mechanical vent on the front axle rusted shut, fortunately for me this was caught before it started leaking. Also, be on the lookout for dirt dobbers plugging holes, especially the down tube on the engine if the tractor sits off more than it’s run.
   / Leak at hst input shaft seal #17
I didn't say it was a great plan😆. I have done some unconventional things.
Just "brain" storming here brother.
   / Leak at hst input shaft seal #18
Okay friend, but it sounds more like a slightly different bs term to me.
   / Leak at hst input shaft seal #20
Seems there are a few too many ex spurts on board already.
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
LOT OF 6" I BEAM (A58374)
LOT OF 6" I BEAM...
2011 KEYSTONE MONTANA 5TH WHEEL CAMPER (A52708)
2011 KEYSTONE...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A56857)
2025 LandHonor...
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
2014 AUDI A6 AWD Sedan (A56859)
2014 AUDI A6 AWD...
