Anybody have experience with a Cheap Cordless Paint Sprayer?
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #11
I have been told that paint wont stick to metal roofing unless you acid etch it first….but i havnt tried it to be sure.
You may have to etch unpainted galvanized steel to paint it, depending on what you are using.
Painted metal cannot be etched.
It must be cleaned. And, should be either sanded, or primed with the right type of primer for adhesion, if it's shinny paint.
I would brush and roll it, before I would buy a cheap sprayer just for that little job.
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #12
Good to know, thanks
So, I used this
To paint this
And it came out like this
I used Rustoleum Massey Ferguson Grey Implement paint. I diluted it 10:1 with Naphtha. The sprayer worked great - Excellent coverage. the sprayer was easy to set up and adjust. I had a few runs, but I was hanging off a ladder, and not seeking perfection. I used a bit more paint than I would have with an air compressor/sprayer, but this went really fast. Still had 2 bars of charge on a 5.0 amp battery after spraying one side.,
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #15
How much paint did you end up using for the entire shed?
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #16
Last year I painted this 24 x 40 ft, barn with the HF electric sprayer
I used Rustoleum thinned with acetone
The HF sprayer is 110 volt but the cordless sprayer should work just fine
I have used this one to spray 5gal of water based poly on pine tongue/grove and trim. No thinning and no issues.
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #17
I should note too that I have used rustoleum in a HvLP spray gun on a few bilco doors and have to re paint about every 8yrs. They get faded real bad and paint flakes off.
   / Anybody have experience with a Cheap Cordless Paint Sprayer? #18
Geez! I thought you were going to paint it so it wasn't so noticeable. That's like a lighthouse on a clear night. :ROFLMAO:
It'll get dull over time :)
I am guessing a bit over 3 quarts for 1/2. Waiting for 3 days in a row of dry weather to do the other side.
23091 (A55758)
23091 (A55758)
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2017 Husqvarna FS 7000 D Walk-Behind Concrete Floor Saw (A55973)
2017 Husqvarna FS...
2003 Big Tex 10PI...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2009 Ford F-150 (A56858)
2009 Ford F-150...
