Do you hardface your ground contact skids and shoes on your implements?
   / Do you hardface your ground contact skids and shoes on your implements? #1
5030
Epic Contributor
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
I do, always, Any implement I own, if it has ground contact shoes or skids, they get hardfaced, no exception and that includes my 'brush hog / slasher' as well as my discbine and the bottom feet on my stump grinder, any metal to ground contact gets hard faced. reason is, renewing worn skids today is an expensive ordeal, especially in the case of my discbine where each skid shoe (I have 10 on it), is expensive, like in the 200 dollar range. All 3 of my FEL buckets are also hard faced on the bottom and lower sides as well.
Because I farm on mostly sandy loam, skid wear is fast and hardfacing them slows down or stops that from happening, plus you can build up the hard facing when it gets worn down, for me it's just proactive, common sense.
I hard face in the shop using my high amperage MIG welder and solid core or flux cored hardfacing wire with inert shielding gas. Hardfacing wire isn't a cheap date but in the long run, less expensive than skid shoe replacement, especially on the disc mower. I have also hard faced the leading endes on my rototiller for the same reason as replacement tines are expensive and hard to replace.
I use Generic had facing wire but you can also hard face with rods in a SMAW machine as well but hard facing rods require a pre heat to around 350 degrees prior to use.
Stody sells hard facing wires and Air Products stocks HF wires as well as rods.
   / Do you hardface your ground contact skids and shoes on your implements? #2
Not a tractor, but I wonder about the bars on the deck of my 30" DR Mower. I do my best to keep them elevated when rolling on pavement or gravel. I'm not a great welder, and I don't want to poke a hole in the bars with a my Lincoln wire feeder.
3 years old and no sign of gouging on the bars....yet
Skid wear will all depend on what type of ground you have, the height of the mower / slasher or if the skids are in ground cantact constantly like in my case with my disc mower.
Far as hard rodding with wire or sticks, you won't burn through so long as you are a competnet welder and kiw how to properly run a weld bead and of course the thickness of the skid shoe itself. I'd not ever attempt to hard rod a severely worn skid as it will be too thin and heat waep anyway. I hard rod (hard surface) mine right awat when they are still virgin metal.
Additionally, the wear bars or skids don't 'gouge', they simply wear way from the abrasive action of the soil they contact and at some point will require replacement. Why hard facing is better, because the OEM wear bars or skids will last 10 times longer than ones that are not hardfaced.
Why do you think that manufacturers like John Deere offer poly sheet upgrades to the soil side of the combines? To reduce skid wear and typical JD, they aren't cheap by a long shot.
   / Do you hardface your ground contact skids and shoes on your implements? #5
On cutting edges, there is a constant ongoing debate; does hard facing help, or hurt. Ive been told hardfacing, which almost never covers the whole cutting edge, destroys the heat treat in the rest of the edge. On hoe buckets, the back and sides, it is common. Part of it I'm sure is, a 6 ft cutting edge is "fairly" affordable; a Cat-330 bucket, not so much. On grader blades; you want even wear, so hard facing, kinda defeats that.
On skid shoes; honestly a piece of 3/16 mild steel, tacked on, as a sacrificial piece, will work for a lot less time/money then hard facing rods/wire.
Whatever blows your dress up. My preference is hardfacing and we just happen to rework large excavator buckets and dozer blades and they all are either hard faced ot get hard faced here at the customers request.
I cannot tell you how many loader buckets I've removed the 'smile' from when people make them smile fron using a light duty material bucket to pry rocks or stumps or put a chain hook on the lower edge and try to hoist something up and the lower sheet deforms and 'smiles' and then the bucket is basically good for beans. I always tell posters on here, if buying a new unit, to specify an excavation bucket over a material bucket, simply becayse the excavation bucket can withstand abuse without smiling. To fix them, I usually have to cut the side sheets loose from the bottom after I hydraulically remove the smile because the side sheets flex and break the welds and have to be jigged and rewelded. I could have a steady diet of them if I wanted to.
I never heard of hard facing the cutting edge on any plow, dirt or otherwise and why most all plow cutting edges are made from high alloy steel and case hardened and stress relieved and we replace a lot of them here as well.
I hardface ALL my ground contact ag tools, always. It extends the working life of expensive shoes and slides and it's way more economical that replacing skids and shoes today as they are all quite expensive. As I stated, I hard face my rototiller tines for the same reason besided, replacing them isn't easy.
Just hard faced the swinging stubble beaters on a farmer's Loftness stubble beater for the same reason, soil erosion from the blades contacting the ground when stubble beating corn on sandy loam ground. That was a job in as much as the Loftness is 16 feet wide, unfolded with 4 swinging blades on each segment.
I had to also machine a new drive end coupler for it as he sucked up an abandoned bed spring while stubble beating and took the drive splines out of the drive coupling. Amazing what hides in corn stubble today... Loftness quoted him 6-12 weeks lead time and 6 grand for the coupler. I own a Dake commercial hydraulic arbor press and all I had to buy was a suitable broach, machine a new coupling to broaching size and broach it. I like making square holes from round holes, always have or splined holes as the case may be.
The older I get, the more discretion I use in quoting and taking on jobs. So long as my 2 rmployees get their 40 hours in and I'm still making a profit, I'm good with it. All the machine tools and tooling and welders are paid for as is the shop building and I've been contemplating retiring totally anyway. My 4 rental properties provide a nice income as well as my retirement and my wife's retirement and I'd like to sit back and smell the dandelions soon.
I cut WAY down on my hay business just because it was detting to be too much so I just run my fields adjacent to the farmstead now. No more running hay on rented ground or custom work. Just my own stuff and that equipment is paid for as well. Doing around 15 acres now, all in Alfalfa and I sell it before I even make it. Same customer all the time and all in net wrapped rounds and he domes with his semi and drop deck and I load them up and off they go. Real turn key. Good for his money as well. 5 or 6 years now and never stuck me one time.
   / Do you hardface your ground contact skids and shoes on your implements? #8
Yes.
   / Do you hardface your ground contact skids and shoes on your implements? #9
With all your talk about your own fabrication business and machine shop. One would think when those shoes wear out you just do some reverse engineering and draw something up in cad and go out to the shop have your "employees" cut it out on your harbor freight plasma cutter and press brake.
Then you would not need to spend all that time laying down a bunch of welds with those top of the line harbor freight welders your preach about!
   / Do you hardface your ground contact skids and shoes on your implements? #10
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
PALLET OF KMC STRIP TILL COULTERS (A52708)
PALLET OF KMC...
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
2018 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2018 Komatsu...
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
