Kohler 10kw propane genset with Wakasha 4cyl.
   / Kohler 10kw propane genset with Wakasha 4cyl. #1
mllud
Gold Member
Missourian
Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
I bought this yesterday.
I don't have it at home yet. It's been sitting in that spot untouched for 26yrs. It's a propane unit. I didn't see an hour meter but will look.
It says 24Volts DC, I'm hoping the generator works as the engine starter. The engine has a hand crank but no starter.
Its old but hoping to use for home backup. Its 10kw 12.5kva with a Wakasha engine
I not a generator expert, I may need help as I go. Comments or suggestions welcome.
About what year?
I see the center gauge is stuck. Poor photos
Here is a photo of the same model as mine that I found online.
   / Kohler 10kw propane genset with Wakasha 4cyl. #2
1800 rpm👍🏻 Looks like it has a recently replaced water pump
   / Kohler 10kw propane genset with Wakasha 4cyl. #3
Good Score! Keep us updated on progress please.
   / Kohler 10kw propane genset with Wakasha 4cyl. #4
I agree the 1800 rpm is nice, it must gear up to get the 3600 rpm to the generator. If it runs a nice sized unit.
   / Kohler 10kw propane genset with Wakasha 4cyl. #5
Looks like Innio is the company name now and still in business. What you bought is still their business, they say they build remote power generation as their specialty.
   / Kohler 10kw propane genset with Wakasha 4cyl. #6
I didn’t see a closeup picture of the alternator nameplate
What makes you sure, it’s not an 1,800 rpm alternator? Just curious.
The radiator has a flange that looks like it may have had a hood or engine cover. I couldn't find a photo of one that has a cover, still searching.
I'll get a photo of that tag next week. I suspect its 1800rpm alternator. It looks like direct shaft to shaft drive.
I would like to muffle the sound. I knew a guy that ran an exhaust into a covered pit. It may run quiet enough as is. I could build a big doghouse with open sides.
That last photo is a photo of one i found on the internet just like mine. (Footnote above photo). That water pump does look new.
Thanks
   / Kohler 10kw propane genset with Wakasha 4cyl. #9
My knowledge of generators is pretty limited, I know in theory they should spin 3600 rpm’s to give 60 cycle but I imagine there is a way to build them for half speed. Mine screams at 3600 rpm’s is why I say it’s nice to be half speed.
   / Kohler 10kw propane genset with Wakasha 4cyl. #10
it depends on the "poles" in the generator head, 2 pole is 3600, 4 pole is 1800 etc.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
10 Ft Fork extensions (A50322)
10 Ft Fork...
Online Buyers Premium (A47384)
Online Buyers...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
