You Know You Are Old When
/ You Know You Are Old When #5,171
My last job was salaried. I got called a lot, and worked a lot of unpaid overtime. Averaged about 50-55 hours per week over 30 years. However, anytime I wanted, I could take off to go see the kids in academic competitions, sports, awards, speaking at church, etc... I was usually the only dad there, and many times the only parent there. I often helped their school with projects, IT work, light carpentry, groundskeeping. In my case, salary was worth it.
/ You Know You Are Old When #5,172
25 years salaried and then with new ownership punching a time clock…
It was very difficult for me to transition but I do earn more per hour and after hour calls not as frequent…
In 2017 I was told not to worry… it will all get settled shortly but here we are… night differential, weekend differential, holiday pay, overtime, etc…
/ You Know You Are Old When #5,174
I just checked on Zillow, my first house I bought @21 in Milpitas ca. in 1967 was $24,500 check out the price now and the property tax is over 20 large! WOW
California: $1.4M for a house smaller than my dining room. :ROFLMAO:
I'd say, "at least it's a nice setting", but it looks like it's surrounded by similar ranchers on all sides! Tell me there's not a freeway in the front yard?
I envy their weather, but not their housing!
/ You Know You Are Old When #5,175
The freeway is about 1 &1/2 miles away! The house is 63 years old, someone did a lot of work over the years, we did add a family/ game room! It was a typical tract home, popcorn ceilings dark stained doors and birch cabs. The addition was 5K in the late sixties!
/ You Know You Are Old When #5,176
90 minutes at home putting out fires because I pick up the phone… need to find the off switch…
/ You Know You Are Old When #5,177
The land of million dollar starter homes?
/ You Know You Are Old When #5,178
Here's what I found happens when you get old working on something, and explains why my Dad before he passed at 88 his garage is still waist deep in everything you can (and can't) imagine everything disassembled.
Whatever you're working on if you need something you won't have it. Doesn't matter you can have six tractor trailer loads of hardware you can never find what you need regardless of how many hours you look. What you WILL find is the thing you needed last week but couldn't find but no longer need.
So if you fabricate what you need at the exact point of completion where it needs just a light touch with a grinder or wire wheel it will fly off at Mach 2 into a black hole somewhere never to be seen again, no matter how well clamped it was with Vice Grips.
When you need a Band-Aid, and you WILL, it will be in a tin box you throw away because none will stick they're so old. Later you'll see one like it sold on ebay for $50 as an antique.
I know...because this was how my day went.
Today was a better day. The hardware store had mild steel 1/4" rod, 3ft about $8. I needed it to be 0.235" so not having a lathe years ago figured out chucking it in a drill (3"piece) and gently hold against fine grit grinding stone, both running max speed. It took a couple hours, a little, measure, repeat.
Then fine sandpaper until 0.235".
Torch beat end that was in drill, hammer, punch & drill.
It's for almost 70 yo Zenith carburetor but it's back like original & works ok.
/ You Know You Are Old When #5,179
View attachment 3423103View attachment 3423104View attachment 3423105
I've only got four lathes, It would likely have taken me as long to make that part, for I would have dropped a couple in the chip pan and had to look, and look and look before giving up and spinning another. ;-)
/ You Know You Are Old When #5,180
When I was hired at my current job of 33 years they offered me salary. I explained to the owner and his right-hand man that I could go down the street and make more by getting a little overtime as an hourly employee.
They left and went into another room to discuss the situation. A few minutes later they came back and offered me more money at an hourly rate than the previous salary offer. I never figured out what was said in the other room, but I took their offer. I still hear complaints to this day from salaried workers at this company.
I had something similar back in the 80s. I was offered a job with a certain amount salaried exempt or salary non-exempt for ~10% less. I took the non-exempt. Good decision as it turned out as a year or so down the road there was a certain amount of mandatory overtime.
That company had an odd policy...the person I interviewed with (technical interview), and who became my boss was not allowed to discuss compensation. That was a separate negotiation with personnel. Ever heard of that before?
I must have made a good impression at my interview because the guy I talked to in personnel told me he'd been instructed to do what it took to get me on board. :)
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
Honda utv cart (A56859)
Honda utv cart...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
