Neighbor's tree fell on my property, now ???
   / Neighbor's tree fell on my property, now ??? #71
I've had my neighbor flatten my fence a couple times
I came home from work and my neighbor came rushing over in a panic over it.
He had it straightened back up as best as he could, with part of the tree still on my yard.
I just started laughing which confused him.
I told him it wasn't a big deal. I helped him clean up the rest of the tree, and then we patched the fence as best we could to keep the dogs contained.
Its just a fence.
   / Neighbor's tree fell on my property, now ??? #72
Its just a fence.
Great attitude!
All the best, Peter
   / Neighbor's tree fell on my property, now ??? #73
This topic came up a lot through my work as a land surveyor. As a rule you are allowed to trim branches that overhang your side of the line. I think that’s what the op did, sort of. Did he damage the tree? Sort of. Unless that tree had great value to the neighbor I can’t see an issue and even then it was damaged already by nature.
Eddie is also correct if the neighbors tree falls on your building the repairs, UNLESS the neighbor should have known, like a dead tree he didn’t take care of.
   / Neighbor's tree fell on my property, now ??? #74
Good Afternoon Winterdeere,
Agreed, I generally sharpen my chains by hand with a round file and when they get really bad I just buy a new one. 😉
I sharpen by hand with the basic file/guide. When the chain does get a little worn, I'll use the Oregon clamp-on sharpener. It's easy enough to use. The key is it is consistent on both sides of the chain.
With a hand file, I do pretty well, but I know I'm still a little off one side to the other. Using the clamp-on sharpener occasionally evens that out.
The other thing, I have extra chains for all my saws. If one is getting a little dull, I 'll sharpen or swap chains and sharpen later. If you don't let them get really dull, they are easier to maintain.
You tractor list reminds me, I miss my old Farmall A :)
And your sig line... How long ago did Thingy say that :D
   / Neighbor's tree fell on my property, now ??? #75
My issue is i keep finding random metal grown up inside the trees
Predominantly barbed wire. But I also found a spike in one of them.
   / Neighbor's tree fell on my property, now ??? #76
I have a bad habit of finding ceramic service wire hanger insulators. I can usually feel when I hit a bolt, but the ceramic feels much smoother as the chain rides it, and can dull a chain every bit as well as metal.
   / Neighbor's tree fell on my property, now ??? #77
If it is split enough that it will peel off, I'd be inclined to get it down instead of leaving it hanging. But use a long enough strap or cable so you are clear of it when it falls.
I like to use a pole saw for things like this so I can reach higher AND have more room to get away.:D
   / Neighbor's tree fell on my property, now ??? #78
When I saw the photo showing the damage to the tree as a result of pulling the damaged limb off I was thinking to myself he should have just cut what was on his side of the fence as others mentioned. That hickory was on it's way to being a potentially valuable tree some day. Now the neighbor has a legitimate beef if he wants to be difficult.
Na It was well on it's way to dying. With that rot going into the core the heart wood will rot down to the ground eventually.
   / Neighbor's tree fell on my property, now ??? #79
I've been on both sides of this debate, if it really even is a debate. I hand-sharpened on the bar for many years, until I found myself trying to jam 15 cords of off-site harvesting into just a few Saturdays per year, and had to minimize down-time.
If I had to go through more than, say, 10 tanks of gas a day, I would probably be more likely to get a machine. As it is, a three-tank day is a big deal for me, so that's 15 minutes of sharpening "work."
   / Neighbor's tree fell on my property, now ??? #80
There is nothing like a pole saw for safety.
You're farther from danger, and you have a head start when you have to run away. It's impossible to cut yourself. You can use it on a ladder safely. You're never supposed to raise a chainsaw above your shoulders, but it's safe with a pole saw. I just can't say enough good things about them.
207280 (A52708)
207280 (A52708)
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
Ford N Series Tractor (A59814)
Ford N Series...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
207278 (A52708)
207278 (A52708)
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
