Property Question-Resolved
/ Property Question-Resolved
My suggestion is would be...If you like the house, buy all of the 10 acres, and turn around and sell the back 5.5 to one of the adjacent landowners. But I would make that deal, before buying.
Or, maybe you could buy the land between the 4 and the 5.5 acres to give you better access. The 8' easment is not wide enough to build access.
And without access, the 5.5 acres is pretty worthless unless there is oil under it.
I dont know that the county would allow the 5.5 to be broken off. I know nowadays, they would never allow a parent parcel to be broken up like this; I think the min access easement is 20 ft, for a single easement, going upto 40 ft if serving more than a single parcel. In theory, they are suppost to try to avoid allowing useless parcels. Noone benefits from micro remainder parcels... and sooner or later, they end up getting tax for taxes, and the county doesn't want/need a bunch of owned micro parcels.
/ Property Question-Resolved #22
It's all zoned Ag.
Ag is a very broad brush....
Ag1 or Ag2 or reserved AG???? The designation means everything as far as permitted uses go. if you are serious, I'd be taking a trip to the township offices and looking hard at the ordinance and their topo maps.
Also curious as to how long it's been on the market and if there are / were any other offers pending or withdrawn.
/ Property Question-Resolved #23
Talk to the county planing department about the parcel.
Around here they have land designated as "Wetlands". Often seasonally wet.
It could well be a negative. Land you have to marginally maintain, but would have very little development or use you could do on it. And it isn't as if it is a pasture you can really see from your back porch.
/ Property Question-Resolved #24
This seems more like a gimmick than an asset. I wonder who designed the subdivision.
Yes, the entire low 5.5 is wetlands; everything is Ag A-2 zoning.
/ Property Question-Resolved #27
I would definitely find out what the taxes will be on that piece of ground.
Perhaps there would be some special tax category for leaving that chunk "natural". Possibly impacting more than just property taxes.
Perhaps a minimum lot size of 9 acres, so they decided to Gerrymander it a bit.
What an absolute mess!!!
So, the rabbit hole... I did some reading on what specifically Ag-2 is, and it's very broad and pretty permissive. Can't go over 35 ft vertical, have set back requirements, ect, no ag ponds larger than 5 acres. Then did some reading on Wetlands; and normal agricultural (including farming and forestry) are allowed, but not mechanical clearing without a permit. No dredging/filling, without a permit (and likely mitigation).
I've kinda talked by self into and out of exploring it further several times. Not a huge fan of the lay out of the main 4.1 acres; as the home, and a small pond take up the middle, and there isn't any good stretches of area to do much with. The 5.5 acres does touch a permanent water hole, of approx 17.5 acres which is nice, if it's got some wildlife/fish.
/ Property Question-Resolved #31
Seen a few parcels and wondered how they came to be and sometimes it was as simple as having enough to subdivide... maybe 10 acre minimums?
There can be opportunities going in eyes wide open...
Conservation easements, tax breaks, acquiring neighboring parcels???
This would be a no brain-er if I could get that 2nd piece right beside it (at a very right price) which would give me 8.2 acres of upland, with 10.5 acres of bottom land, with direct-easy access to one small water hole (2.5 acres) and slightly less direct/easy access to a 17.5 acre pond. But i dont want to assume that would ever be available.
/ Property Question-Resolved #33
That sure would make things a lot better....Hope it works out for you
When wife got home from work, I showed her the bizarre layout. She seemed less than thrilled with it, and kinda lost a lot of 'shine'. Still gonna keep an eye on it, but probably not gonna move forward unless the price adjusts downward.
/ Property Question-Resolved #36
I’ve looked at properties with weird parcel shapes before, and they can be tricky to figure out. If the extra land isn’t really usable or accessible, it’s hard to justify paying much more for it. Even for something like a food plot or livestock, if the access is that limited, it might not be worth the hassle. If it has some seasonal use, maybe a little added value, but I wouldn’t count it as full acreage in terms of pricing.
If you're planning to buy and hold as an investment, cost segregation studies from Cost Segregation Guys | Maximize Real Estate Tax Savings & ROI could be useful for maximizing tax benefits. I came across this site that specializes in cost segregation studies, which might help if you're considering tax advantages for property investments.
/ Property Question-Resolved #37
Reviving and old dead thread?
Harder to sell weird shaped properties for top dollar...like trying to sell an off grid home.
I dont remember what the asking price originally was, but it sold for $309,500. Thats pretty good for the upland parcel and home. Happy we didn't go with this one.
The one we did buy is also a bit oddly shaped, kinda hour glass shaped, with a bigger top and bottom, and a narrow middle.
/ Property Question-Resolved #40
Land that floods isnt land and has no value unless you own all 4 sides of it.
2002 International 9200i Truck (A61307)
2002 International...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
2022 Timpte 1420 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1420...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
