1988 John Deere Hydro 175 - Engine stalls when I engage the blades
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #21
Wouldn’t a bad clutch either not engage or blow a fuse vs killing the ignition circuit?
He just bought this used. I never know what I'm getting into with used equipment or how good the previous work has been done. or what shortcuts they took.
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #22
In my experience, when the PTO clutch stops working, it stops working. It's not hit or miss. It's not on first try, then works the rest of the day. It's just dead.
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #23
It’s a safety or reverse switch. It think your either not on the seat, or trying to backup while mowing without engaging an override.
It’s a safety or reverse switch. It think your either not on the seat, or trying to backup whole mowing without engaging an override.
What overrides should I put in place other than the seat bypass?
So I completely unhooked the clutch electrically, turned the mower on, engaged the switch and it still died. Does this indicate a bad switch or still could be a bad clutch?
Sorry not really used to working on these engines.
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #26
Some setups you can't bypass the seat switch. The wiring has a bypass shorting clip built into it that if unplugged will short the two prongs making it think that nobody is in the seat. And to the OP I would suspect you have a bad seat switch or something related to the seat switch
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #27
If you're still cutting out with the clutch disconnected electrically, the problem is between the pto switch and the connector. so either a shorted wire/bad safety switch/ or bad pto switch. Get a wiring diagram & start tracing out the various legs & components.
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #28
To the OP: Does that have a mower/reverse safety switch? Is the tractor in neutral or a forward gear? (not just clutch depressed while in reverse) I had an old craftsman with one, but as I remember it could be bypassed intentionally if you wanted to mow in reverse.
No safety switch. There is only a hand lever that I have to “shift” into forward, neutral, reverse. I’ve tried engaging in all 3 modes. Same result
   / 1988 John Deere Hydro 175 - Engine stalls when I engage the blades #30
Mine had a little yellow button I had to push in order for the mower to stay running in reverse. It was to the left of steering wheel. I thought the yellow lever to engage the mower was a manual engagement, not electric. Certainly felt manual. I guess different year???
Do all pulleys spin freely when not engaged? If the engagement is manual like I thought mine was, check that pulley.
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
1996 Pro Gator 160V (A54865)
1996 Pro Gator...
More info coming soon! (A55851)
More info coming...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
