Who still drives a stick in 2025?
   / Who still drives a stick in 2025? #261
That's half true. Look at the heat generated by an automatic transmission, which is to any physicist, "loss". Autos are not more efficient than manuals, but perhaps in many "in town" environments they may yield better net efficiency than most human operators of a manual transmission.
Really, what I think killed manual trans is a combination of the following:
  1. Price pressure. It costs auto manufacturers more to engineer, test, and manufacture both variants. When competing with another brand that only does one, those who offer both will always have much higher costs.
  2. Emissions testing costs of the manual is much higher than auto, or so I'm told.
  3. Crash safety testing would require them to test both variants, or so I'm told.
  4. New car buyers have always favored auto, whether due to age or other variables. We've seen this play out for decades, as it seems used car buyers (younger?) have always had a greater thirst for manuals, causing availability issues in used market.
Traffic is also horrendous now, way worse than 10 and especially 20+ years ago.
   / Who still drives a stick in 2025? #262
During acceleration there is some loss due to the hydraulic flow in an auto. But all the current automatic transmissions lock up in the higher gears.
Mine locks in gears 2-6.
Only 1 is unlocked so the truck won’t stall at a stop.
   / Who still drives a stick in 2025? #263
You're going to have to go back to the 1990's to find one from Ford or Chevy, or early 2000's for Dodge and Toyota. I think I already said it about 20 pages back in this thread, but I switched to Dodge in 2005 because they were the only American brand still offering manual trans in a full-size 4x4 pickup with a v8 and extended cab.
You could still get a 6 speed manual Getrag up to 2018 if you speced the Cummins instead of Hemi in the HD trucks. Parts for repair would be from MAGNA because of the buyout.
   / Who still drives a stick in 2025? #264
About 7 more weeks.
Salt and road grit need to be gone.
Clear sunny weather.
   / Who still drives a stick in 2025? #266
It's not really up for debate. Look at the Monroney stickers. Today's automatics are achieving equal or better MPG than manuals in the same vehicles. There isn't nearly as much parasitic loss through a modern automatic as their used to be, there are double the gears, and the ECU can totally control operation. So, automatics are now more efficient than manuals.
And, for pickup trucks in particular autos can hold more input torque which is why the OEs have all gone away from manuals on the diesels. Ram tried to hold on as long as they could, but even then they would derate the Cummins if the manual was paired to it.
Still, I prefer a stick in my muscle cars so my Challenger 392 has a Tremec 6060. But I'll always take the auto in a pickup truck.
   / Who still drives a stick in 2025? #267
Manuals are maintenance free, now automatic transmission required filter change, belt and oil change (CTV).
   / Who still drives a stick in 2025? #268
Manuals are not maintenance free. There are recommended fluid change intervals. And clutches are sure enough not maintenance free. They aren’t a fun replacement item.
   / Who still drives a stick in 2025? #269
Exactly. Two years ago I spent over $4k getting a manual transmission rebuilt at 100k miles because the synchros were worn out and I took that opportunity to install a new clutch to minimize future costs. Plus, they need fluid changes every 60k.
By contrast today's automatics have 150k mile service intervals, or beyond. I've seen guys go 300k miles without touching the auto trans (which I do not recommend, but it happens a LOT).
   / Who still drives a stick in 2025? #270
Avid Jeeper here.
I've had so many in my day... all have been two doors, and manual transmission. My current Jeep is a 2022 Rubicon... two door, manual 6 speed transmission.
2013 KUBOTA SVL90-2 SKID STEER (A52709)
2013 KUBOTA...
(2) 3/8"x1/2" RATCHET BINDERS (A52708)
(2) 3/8"x1/2"...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2020 ASV RT-120 FORESTRY SKID STEER (A52709)
2020 ASV RT-120...
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
