/ Your last generator Maintenance Run
We have a Generac 22KW 2014 air cooled in the Pacific Northwest.
We had to evacuate for 11 days because of fire it ran the whole time except for oil check every few days, and never an issue with overheating and it was in the summer months, it runs on propane! Still has the original battery!👍🏻☮️✌🏻
1) I hope your property had no fire damage.
2) If that's how your luck usually runs (11 days, nobody home, no issue w. a 10 y/o battery), then I'll pay you to buy and mail me lottery tickets ! :cool: (y)
3) Easy to spend somebody else's money (and, I'm not known for throwing mine away) but that 2014 battery has been well-amortized by now..... after that 11 day run, I'd have trouble sleeping w/o a new battery in your gen. A "while" back in this thread, grs had some good #'s on battery life expectancy (other people listed info too, but he probably changes more batteries on Generacs in a year, than the rest of us ever see). IIRC, 10 years on that class of battery is getting well out on the far edge of expected life.
Rgds, D.
/ Your last generator Maintenance Run #7,272
air cooled diesels are not uncommon in Europe, Hatz and Deutz have been around forever, yanmar makes some air cooled diesels too
/ Your last generator Maintenance Run #7,273
one comment I read was interesting in that air cooled generators warm up faster than water cooled, so
load can be turned on faster.
I've watched a lot of youtube videos on starting big generators. I absolutely cringe when I see them start racing at full
rpm ten seconds later. Unless the oil is kept warm, only exception.
Generac kicks on around 10 to 12 seconds.
how many of us would take our cars out in zero degree weather and floor it to redline
ten seconds later? (guys with diesels at least can often plug them in at night)
Always wondered why they didn't let the motor run for at least 30 seconds.
if you are a hospital, well, keep your oil warm and I get it. Hospitals probably need to go solid state too, let's keep the
heart pump running while you operate on me please.............
Big ships and trains and ? have prelubers, not sure about oil warmers.
I always let my portable gen warm up for several minutes.
By the time I get back down in the basement with my flashlight fiddling with the panel
to switch over power, it's warmed up a little.
I think if I had an automatic gen here, like I used to, I'd have a heater element of some sort for the gen.
when mornings are zero degrees out, or colder, that is just not the time to lose your power. Not all of us have woodstoves
or fireplaces so this gets real in a hurry. I guess you have to have a heating pad under the battery too.
/ Your last generator Maintenance Run #7,275
Modern premium synthetic oils address all your concerns…😉
/ Your last generator Maintenance Run #7,276
Not right exactly. Diesel gensets are 4 pole / 1800 rpm. Gas is 2 pole / 3600 rpm. I own both btw. Gas can be water or air cooled but diesels are almost always water cooled. In fact I don't know of any major producer that uses an air cooled diesel engine.
I have one. 6KW Genpro , single cylinder Lombardi diesel 3600 RPM 4 pole.
/ Your last generator Maintenance Run #7,278
They are not uncommon here in the US either, at least not here in the farming community. I have (5) Deutz and SLH air cooled diesels myself, and I've had others.
I really like the SLH made air cooled diesels...
SR
/ Your last generator Maintenance Run #7,279
3600 rpm directly to a 4 pole generator head would give you 120 hz power, unless that 3600 rpm engine has a gearbox between it and the head if it is turning at 3600 rpm directly to the generator head that would be a 2 pole generator head.
/ Your last generator Maintenance Run #7,280
Exactly. 2 pole = 3600, 4 pole = 1800. Having said that, Inverters can have multiple poles as the frequency as well as output voltage is 100% electronically controlled. Why you don't see large output units as they would be prohibitively expensive.
Far as diesel powered units, smaller ones I imagine could be 3600 rpm pto but the larger ones will be almost all 1800 pto.
Not familiar with small air cooled diesels though I'd consider a Hatz as a repower engine if they weren't prohibitively expensive.
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
2024 Hurrican GF480 (A60463)
2024 Hurrican...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2020 DRAGON ESP...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
