EV owners of today and tomorrow
Status
Not open for further replies.
   / EV owners of today and tomorrow #1,721
The RamCharger is supposed to be a series or serial hybrid, an idea I like.
And could be tempted to buy.
You can like it but it will consume much more fuel in ICE mode than it would if there was a mechanical path from ICE to wheels.
What is the point of making the effort if one is to consume more fuel as a result? For a diesel-electric locomotive the point is a mechanical transmission of the size needed and the multitude of ratios dwarfs the inefficiency.
   / EV owners of today and tomorrow #1,722
You spouted that off more then once, I do believe you are completely in error.
   / EV owners of today and tomorrow #1,723
Your evidence please?
ICE-generator-battery-motor-wheels is much simpler than ICE to wheels and generator. So why do all current production hybrid automobiles use the parallel model?
If a series hybrid was practical then why do we not see Teslas towing genset trailers as a series hybrid conversion?
   / EV owners of today and tomorrow #1,724
Anytime you add a device between where the power comes from and where it is delivered there will be a loss. If may not be much, but it is not zero.
If an ICE can run at its most efficient operating load to power a generator that charges a battery, it may do better than using it to deliver power directly to the drive train. It must do better than the losses incurred with the generator and battery system.
   / EV owners of today and tomorrow #1,725
This does a good job of showing how GM sold out the US car industry to China and established Tesla as the the de facto leader in automotive today. The funny thing Tesla is moving to only be 10% car company as the old guys fade away because they cannot be competitive against the Chinese.
   / EV owners of today and tomorrow #1,726
Excellent post, Don. In addition to this, I suspect an ICE configured and tuned to run a narrow range of RPM for the sole purpose of charging batteries, can probably run at a much higher average efficiency, than one which needs to spool a wide range of RPM's thru the gears during acceleration.
The modern high gear count transmissions are aimed at solving this problem, keeping the engine operating closer to peak power or peak efficiency, not always the same point, and likely a big part of the difference in running "Eco mode" versus "Sport mode" on your automatic transmission. But a single-speed tuning for the purpose of charging batteries, can be really optimized very nicely for peak efficiency.
   / EV owners of today and tomorrow #1,727
This is in reference to hybrid vehicles.
   / EV owners of today and tomorrow #1,728
Where is yours?? All I've heard from you are claims and statements, no facts because they are not out there at this time.
An ICE running at optimized rpm when needed or even two different optimized rpm such as a cruise and high power. Using the cruise to just maintain a battery or even shutting off when the battery is charged and the vehicle is cruising butt kicking back in as the battery is depleted or pulling a steep grade which requires much more hp (energy) then cruising.
   / EV owners of today and tomorrow #1,729
   / EV owners of today and tomorrow #1,730
It might. But those who have tried have all failed on automobile sized systems.
Locomotives, earth movers, ships, are another story.
Status
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2007 CATERPILLAR 420E BACKHOE (A52707)
2007 CATERPILLAR...
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
