2023 Kubota RTVX 1100 C LED Lights
   / 2023 Kubota RTVX 1100 C LED Lights #1
tassmannn
Saint Marks, Fl
1985 Ford F250 6.9 IDI, 2006 Ford F250 6.0 (bulletproofed), JD 5075E, JD 994R, JD 310J (5045Ht054), Kubota RTVX 1100C, 2006 CAT D4G, 1954 Ferguson TO30, 2021 John Deere 333G High Flow
I got a 2023 Kubota rtvx 1100C diesel, and having a hard time finding accessories for it. I want to replace the headlights with LED and was wondering if anyone has a link to some plug-and-play LED headlights. I use to own a polaris Ranger, and accessories seem to be easier to find. I really appreciate any help you can provide.
   / 2023 Kubota RTVX 1100 C LED Lights #2
   / 2023 Kubota RTVX 1100 C LED Lights #3
I went 110 volt LED. Made a tray for the Honda 2K generator to go in the receiver hitch.
Hardly comes off idle with all the LED's on. Can shut off the RTV and still light up the world.
   / 2023 Kubota RTVX 1100 C LED Lights #4
I left my headlight bulbs stock and just added a light bar on front and two LED work lights on the back of cab.
I see the newest version of the RTV cab has low and high beam headlights.
   / 2023 Kubota RTVX 1100 C LED Lights #5
Headlights and LED worklamps. Will need to do some wiring. Search You-Tube on 5 Prong switches is good place to look as any 1100C lighting videos I have seen are not worth much "Look how bright they are!"
If you are lazy the Kubota Accessory Work Lights come with brackets and wiring harness for Plug and play, but are 3 x 5 times the prices of aftermarket stuff.
I found these on Everything Kubota. It comes with everything you need to install. It's a bit involved to install them since they come with their own wiring harness and relay, but it's worth the time. The only thing is that the 3-wire switch doesn't work efficiently with factory on-off, but it comes with a push-on/off button. I like how the bracket keeps the profile low so it fits in the garage on the 27" Tires
I also found some LED Headlights on eBay that work great. The only thing I needed to do was double up the gasket to allow it to tighten in the socket better.
   / 2023 Kubota RTVX 1100 C LED Lights #8
View attachment 2194010View attachment 2194031View attachment 2196072
How bright are those things? They look like you could light up a stadium! $70 on our new to us rig is extremely bright.
   / 2023 Kubota RTVX 1100 C LED Lights #9
I've had an RTV1100 for some time. As with several other tractors, I've found the Nilights solutions to be excellent. You choose the bar you want or other smaller lights and Nilights has the harness and switches you need. Just look on Amazon. I believe this kind of solution would beat any replacement headlights for the RTV series in terms of lumen output. https://www.amazon.com/nilights/s?k=nilights
That's pretty cool. I did the same thing on a boat I used to own. It was a 30' Glacier Bay. It didn't have a generator but had A/C and other 110-volt stuff that only worked when on Shore Power. I had a box made and a stainless exhaust manifold. Gave us air conditioning when offshore on those hot summer days!
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A56858)
2008 Ford E-350...
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
