EV owners of today and tomorrow
Status
Not open for further replies.
   / EV owners of today and tomorrow #1,491
2. The earth is is a propane tank.
Lets be clear, opaque propane tanks are spherical.
The Flat Earth is inside a propane tank because under Flat Earth Doctrine that is the only way to contain the atmosphere.
Terry Pratchett's discworld didn't need a perimeter ice wall nor propane tank ceiling.
   / EV owners of today and tomorrow #1,492
What does that prove to you? (Assuming it’s real).
Your High Priests have long said the 24 Hour Sun was impossible on their Flat Earth, then all on The Final Experiment witnessed it.
Flat Earth debunked, disproven, to it's highest and most devote practitioners.
   / EV owners of today and tomorrow #1,493
The day after russia denies shooting down a passenger plane over chechnea, then denies it emergency landing, they run this commercial.
   / EV owners of today and tomorrow #1,495
   / EV owners of today and tomorrow #1,496
Dodge with a kickass HEV?
   / EV owners of today and tomorrow #1,497
Just what I've been wanting to see for 10 years or more, only I wanted a small diesel for a power plant with a two speed system to run the auxiliary systems AC and a constant 12 volt. Run at a low rpm when just AC or 12 volt DC then kick the engine up to an 1800 or 2200 rpm run speed for the generator for the main battery. Then use the small engines "waste" heat for battery temperature management and cab heating.
   / EV owners of today and tomorrow #1,498
What GM could have done almost a decade ago by upsizing the Volt technology to get an extended Range truck and been out ahead of RAM on this but they killed it instead. Now they are behind in extended range hi MPG trucks that can tow long distance that don't require a 200KWH battery. GM missed a big opportunity. Ford has done pretty well with theirs.
I think the Ramcharger will do well and a lot of truck owners that actually use their trucks will buy it before a Cybertruck.
   / EV owners of today and tomorrow #1,500
Tesla does not have a competitor to a work truck that can tow long distance. Maybe it is in the works. I am not convinced EV trucks will be where they need to be to compete without much lighter and energy dense batteries.
Assuming you mean pickup trucks and the like, I think they will be among the last to make the switch, which is probably why Dodge's approach with the Ramcharger makes sense. Total HEV, no range or charging issues, and 500 hp to boot.
Status
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Butterfly Artwork (A55758)
Butterfly Artwork...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
