WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,403
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Exactly. Most tubeless tractor tire leaks seem to be at the bead, and a small smear of bead sealant is a much nicer and better fix than any mess of crap you can pour into the tire.Where's the leak?
Or if it’s from a tread puncture, then just plug the damn thing, also a cleaner and more permanent fix. And if it’s in a side wall, chances are the tire may be due for replacement.
I guess I might resort to slime, if there were ever a leak I couldn’t find. But honestly, in nearly 50 years of repairing tires on everything from bicycles and lawnmowers, to pickup trucks and tractors, that has never happened. There have been a few difficult cases where I’ve had to fill a tub with water, and rotate the tire thru it, but I’ve always found the leak one way or another.
A little dish soap and water in a squirt bottle will find the leak real quick and easy, in nearly every case. Just take the empty bottle from the kitchen, next time you finish one, and refill with water. There’s a good amount of soap residue left in an empty bottle of that stuff. It’ll go a lot farther, if you put it into an actual spray bottle.
