You Know You Are Old When
   / You Know You Are Old When #3,872
I forgot stage 4...
   / You Know You Are Old When #3,874
I'm 78 with osteo arthritis in every joint, doesn't stop me from doing anything. I just can't work too long and when I'm done
I feel like somebody beat me up with a baseball bat or I fell off of a roof.
You know you are old when accepting pain everyday is just proof you are still alive!
   / You Know You Are Old When #3,877
15 cents for the ones that were propeller driven by a wound-up rubber band.
We used to tape a smoke bomb with a short fuse and a firecracker with a long fuse to them and twist the fuses together, light it and off it goes.
Looked like engine trouble before it blew up. šŸ™ƒ
   / You Know You Are Old When #3,878
The hobby store used to sell a "jet engine"...wonder if anyone remembers. All it was was a metal container about 2", maybe 2.5" long about 3/4" diameter the tapered top unscrewed. It had a small hole in it. It came with pellets, you'd put one in, screw top on & put a fuse through the hole. It had a metal bracket. You'd light fuse & snap it on bracket.
I mounted one to a plastic model car. A friend & I were at either end of the concrete porch so he could flip it around to me. It worked great until it melted through the car's roof!
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A58017)
2005 INTERNATIONAL...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
2003 Big Tex 10PI...
