m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 3,994
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
good morning, 54 going to 66
The jack posts are set up and tightened. Also set up the rotating laser on the tripod for convenient measurement of progress. Plan is to rotate screws on the jacks half a turn per week. So will take a number of weeks to get to level.
Stacked some more wood taking care to lean in so the stack when drying does not tumble over.
Aired up the tires on the tractor. 28 psi front and 18 rear. Rotated the filled tires to the top but still had fluid coming out. Maybe because they were low in pressure pushing the fluid up higher.
Blew out the gauge by pushing the middle pin with a screw driver to drive the fluid out of the Milton gauge and air valve.
