New Holland TC45D won't start fuel supply issue
   / New Holland TC45D won't start fuel supply issue #31
It surprised me when I took the banjo bolt out and it fired right up after putting it back. I broke everything free and bled while pumping air into the tank and I still wasn't getting anything past the banjo. How did you pump air through the steel line after the banjo?
I know nothing at all about diesel and not very much about fuel injection :)
   / New Holland TC45D won't start fuel supply issue #32
I have a 2003 New Holland TC45D that I'm having issues with. I have a good supply of fuel when I loosen the bolt on top of the fuel pump to bleed the lines, but I cannot get any fuel to the injectors. I have tried loosening them and cranking when they are loose, but no fuel arrives. Any suggestions?
Eco-Fuels in some states gum up the injector pump
Has it been sitting long?
Is the fuel shut-off solenoid on all the time?
   / New Holland TC45D won't start fuel supply issue #33
I have used on and off road diesel. Usually doesn't sit more then a week without working on the drive or trails
Whoops I shoulda looked at the quote first :)
   / New Holland TC45D won't start fuel supply issue #34
I have had the tank out and cleaned it. I like the idea of bypassing the shut off I will try that tomorrow. The ignition switch was replaced not too long ago because key got broke off. I've had the tank out and cleaned it out. The only line I haven't replaced is tank to filter. Was hoping to avoid that. Could it leak down there after tractor is shut off from that line. I get solid fuel flow with out leaks the whole way to banjo/bleed bolt
How hard is it to get the tank out and what is the process to remove it?
   / New Holland TC45D won't start fuel supply issue #35
Basically two nuts and bolts between frame and tank near the top. It was a lot easier then I thought it would be
   / New Holland TC45D won't start fuel supply issue #37
Does anyone know how much fuel should come out of the return line off the top of the shutoff? Cranked it with out it attached and got a lot more3 then expected!
   / New Holland TC45D won't start fuel supply issue #38
Pinch it off with some vise grips and see what happens..
Where does the line go or start from.?
   / New Holland TC45D won't start fuel supply issue #39
Takes fuel from the filter back to the top of the tank tank.
Funny it's leaking quite a bit even though it's not running.
My bad. I just looked again and it comes off the injector rail. But when I blew air through it from the tank it blows out. Of that line
   / New Holland TC45D won't start fuel supply issue #40
This is a big shift in my understanding of this system. That line takes raw fuel from the injector lines and dumps it back to the filter. So where does the line from the top of the tank go and it's function? I thought it just recovered fuel.
Is there a diagram somewhere that shows fuel flow? I blew some air in the tank and that line brought a lot of fuel up.
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
