Ground hornets! [emoji2962]
/ Ground hornets! #1
Fuddyduddy1952
Super Member
john deere
I cut some trees down and have a brush pile using tractor and truck. Monday I'm using the FEL bucket pushing brush when...BEES!!! So it's high gear wide open back to shed . Luckily just 3 stings. Today I'm in same area and found the nest. They were swarming all around this hole, nest was like the gray paper ones you see in trees. This evening (dusk) I was going to pour maybe a quart or two of gasoline in it (and light it???).
I assume they're hornets?
If I don't reply back...call 911...
/ Ground hornets! #3
I was out walk behind roto-tilling when I went over a ground hornets nest. The problem is that you don't see them coming, and by the time you realize what's happening, you've been stung half a dozen times. You were lucky to get by with 3!
/ Ground hornets! #4
Save your money - you only need a couple oz of gas. Take some plastic and a rim out there at night. Slap the plastic over the nest and plop the rim on top. Inject the gas through a small hole in the plastic. The fumes will kill them overnight.
/ Ground hornets! #5
Yep - nasty ground yellow jackets that usually fly faster than I can run - have hit many of these over the years weed trimming and mowing - you're lucky to have just 3 stings.
I wait till dark and pour a half gallon or so mix of permethrin and water in the hole then toss a half bucket of dirt on top - they are all dead in the morning.
/ Ground hornets! #8
My solution to yellow jackets isn't quite so elegant. I wait until it gets nearly dark outside so they return to their nest then put an old shop rag over the end of a stick and stuff it into the hole they dug. I then pour a cup full of diesel on the rag and light it. It's not pretty but it works.
/ Ground hornets! #9
@Fuddyduddy1952 I'm glad that you got out in time!
I use a turkey baster filled with talcum powder or diatomaceous earth. I've never been stung doing that. It sounds bad, but I have had better luck with that compared to hornet sprays.
Open flames are a no-no here for basically all of the hornet/yellow jacket season.
All the best,
Peter
/ Ground hornets! #10
I was not that lucky 20/30 stings, in the ground nest of yellow jackets and they hurt like heil
I'm surprised I did not get sick or end up in the hospital.
No need to light the gasoline it's the fumes that kill them.
John Deere S350 (A60462)
John Deere S350...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2015 John Deere 3038E (A60462)
2015 John Deere...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
2022 DODGE RAM 2500 SERVICE TRUCK (A60736)
2022 DODGE RAM...
