Thoughts on a 2019 LS XR3135H- only 45 hrs??
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #31
I'd opt for the cab if only used in the summer for mowing. Just a note about the HP, my father has an L235 that will turn a 5ft bush hog pretty well, but you have to slow down in thick grass. An XR3135 should do at least that. Depends what you're mowing. I cut my parents' 19 acre field a few times with the Kubota, but it took forever. If time isn't an issue, then definitely go for comfort.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #32
For what its' worth, here is my plate. It's an R-Model, whatever that means. It reality, its an XR4145C. It must be some weird manufacturing code they use. View attachment 880348
Because that's the plate for the ROPS structure. Every ROPS is registered at the dealer, basically "certifying" that the ROPS was specifically engineered for the specific tractor.... legal stuff.
The tractor plate should be on the side of the frame, just under the engine.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #33
Ok- So here is the vin plate- when I called the dealer it shows that he bought it from- they said it does not show in their records?? I called another dealer and they said unless it was bought there they cannot look it up-Also why would it show as a model XR40RFA if the tractor show it as a XR3135??- Again thanks so much for all the advice!!
As in my previous post, that's the ROPS plate.
Look under the engine, on the frame.
Guys thanks for all your advice- So I just put an offer in on the 2021 with the cab- we will see- Still not sure about it having turf tires though- but the cab does seem like a good idea- Was there any changes betwen the 2019 model and the 2021 model xr3135??
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #35
Some people actually prefer turf tires because they tear up the turf a little less
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #36
As far as I know, no. Nothing major anyway. I know you'll be happy with the cab model. And try those turf tires while out mowing. They might do pretty well! Just stay out of the mud.
BOUGHT IT!!!!
So I got the 2021 cab with 112 hrs on it-- the dealer is going to load the tires so it will help- He felt that the Titan Cross trac C/S tires now that they will be loaded should be fine?? Only bad part is that I wont be up to the house till Aug. 8th so that is when he is going to deliver- BUMMER!!!
Guys- thank so much for all your advice and patience!!!
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #38
AWESOME! Congrats!
The filled tires will defiantly help! You'll be way more stable. More weight also equals more traction. Unless you're diving in the mud, you should be just fine. And when they wear out (in 25 years) then you can replace them with a more aggressive tread.
Again, CONGRATS! 🄳
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #39
Congrats! You scored a really nice tractor!
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #40
Hello- Looking to replace my Dads 40 yr old Kubota L235 to mow about 20ish acres of field in NH- I am going to buy used as we only use it a few times a year ( It is a summer place)- I am looking at a Massey 1735M and just saw the LS XR3135H go up for sale- It comes with Third function valve,Worksaver 48" Grapple, Quick Attach and Forks- I can get it for around $20K- Any issues with this model??- both have the loader-which do you think is the better tractor for same $$$$-- thks so much-
I would go for the MF if it was me. That is if you have a close dealer. We had a couple MF's going up on the farm. We always had good luck with them.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
Unused 20x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 20x20...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
